Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-29-2012, 02:55 PM
lwclark's Avatar
lwclark lwclark is offline
1960 Ford F-100
lwclark is starting off with a positive reputation.
Rear axle ratio change?
How much of a hassle is it to change the rear axle gear ratio in a stock 1960 F100? Where would I get another ratio gear?
Thanks.
__________________
Larry
1960 F100 Custom Cab Styleside
1966 MGB
I have no idea what I'm doing. May as well get started.
  #2 (permalink)
Old 04-29-2012, 08:02 PM
spurredon's Avatar
spurredon spurredon is offline
Garage is empty, add now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Haven't done it personally. My buddy did my last one. Just looking at the shop manual I think it doable but will take a bit of time first time thru. Also, it will require a press, bearing puller, micrometer and perhaps more that I can't think of at the moment.
Good reason to buy more tools if you need to!
  #3 (permalink)
Old 04-30-2012, 09:13 AM
we56 we56 is offline
we56 is starting off with a positive reputation.
Taking in consideration it is a 9" ford with the third member out pull out side saddles on rear and take nut off pinion pull apart check carrier bearings and pinion bearings, i would then get a ford 9'' rebuild kit several companies sell them then find ratio of gear you want and have the kit put in and get lash set right! my brother set mine i could ask him?
  #4 (permalink)
Old 04-30-2012, 10:15 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I'm quite sure that with a 1/2 ton it's a really simple swap to install a later complete rear axle. I had to move the spring perches on my f350, but don't think it's necessary on the f100. Even with the work I did, it was still easier and cheaper than getting into the innards and replacing the ring and pinion. I'm no expert here, I only have done one of them, mine.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 04-30-2012, 10:34 AM
manglass manglass is offline
manglass is gaining momentum as a positive member of FTE.
As far as I remember, it is a standard 28 spline 9" Ford rear. The simplest and least expensive way to change ratio is go to the junkyard or pull-a-part and find a full size 60's or 70's car or 57-80 something F-100/150 with a ratio you desire. The center section is removeable and should bolt right into your truck. Avoid high performance models as they might have 31 spline axles and have someone check an interchange manual to make sure my memory is on target.
Lou Manglass
  #6 (permalink)
Old 04-30-2012, 12:23 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1957/67 F100's use the same 28 spline axle shafts.
Be careful, some 1968/72 F100 9's have a 9 3/8" ring gear and 31 spline axleshafts. Others have a 9" ring gear and 28 spline axle shafts.
Be careful, some 1973/79 F100's, 1975 F100's have 28 spline axle shafts, some have 31 spline axle shafts. There is no way to know unless you either tear it apart, or get the rear axle tag, give it to someone that has the parts catalog.
And, be aware that some 1974/79 Passenger Cars/F100/150's/Bronco's and E100/150's have a ball axle bearing and separate seal, while others have tapered roller axle bearing/seal combo.
The only way to find out is to pull an axle.
btw: How is a person to know on all the vehicles you listed, what the rear axle ratio is, especially if the rear axle tag is missing?
btw part II: Some 1967/78 full sized Fords/Mercs have the WER 8.7 integral rear axle.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #7 (permalink)
Old 04-30-2012, 01:16 PM
Absolutely correct Bill. That's why I also suggested to check an interchange manual to cover those "subtleties" that can ruin an otherwise easy swap. Of course, the only simple way to tell the ratio is by the tag (assuming the original tag is still intact), otherwise it becomes necessary to get a look at the ring and pinion itself to be sure. I made the assumption that the poster was already aware of that. My point was, there are lots of axle ratios in lots of 9 inch "pumpkins" that will fit in the OP's truck without going to the extent & expense of a ring and pinion swap. Then he only has to mess around with making the speedometer accurate. He's certainly entitled to spend his time and money any way he likes. I have no doubt the OP will end up with a better product in the long run if he completely overhauls his original unit with NOS parts, I just think he will be time and many, many dollars ahead by swapping the center section with a good used piece of his choice. I don't know what the junkyards are like in Texas (where Larry lives) but here in Atlanta, I could go out this afternoon and come home with a few that would fit before dinner time.
By the way, thanks for all you do around here. Some may not appreciate it but as a former (Ford) "wrench," I do.
Lou Manglass
  #8 (permalink)
Old 04-30-2012, 02:53 PM
lwclark's Avatar
1960 Ford F-100
Thanks for the input guys.
I really enjoy and benefit from this forum and its contributors.
__________________
Larry
1966 MGB
  #9 (permalink)
Old 05-01-2012, 06:28 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Around here 9 inch center sections are quite plentiful and every ford guy has a few extra punkins around. Even the junkyards have school busses full of them already removed and if it isn't an LS they are dirt cheap. I have a couple 28 spline limited slips under my bench for the 29 PRU hotrod, and I've given away maybe 4-5 opens in the last year that were 3.00, 3.25. 3.50s and so on.
Network, ask the parts store guys, you'll find the Ford guys with the stuff you need.
I will say that every 67-72 I ever pulled was a 28, even though some were supposed to be 31 they must be rare. That's not including a few Dana axles in certain 67s but that's a whole different unrelated deal.
Tags
1960, 1978, 2004, axle, axsle, end, f100, f150, f250, ford, forum, performance, ratio, rear, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
