Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 04-29-2012, 10:32 AM
MAS96F150's Avatar
MAS96F150 MAS96F150 is offline
1996 Ford F-150
MAS96F150 is starting off with a positive reputation.
94 lighning tc not locking
i just picked up this 94 lightning a few days ago. has 133,000 miles and runs and drives fine aside from needing radius arm bracket and bushings. i have noticed that it seems like it never locks the torque converter when driving. haven't driven anywhere but around town so havent really been over 45 with it. check engine light is off. any advice is appreciated thanks
__________________
*96 F150 ext cab short box, 2wd 302 mazda 5 speed swap, Hurst Shifter
69 351W heads, Scorpion 1.6 roller rockers, E303 cam
ford racing 4.10 gears with detroit locker
pacesetter LT's 2.5 dual Pypes violator mufflers and 3 inch side pipes
* 94 Lighning,all stock, for now
  #2 (permalink)
Old 04-29-2012, 04:28 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Cycle the flasher button in and out a few times. Does the cruise control work?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 04-29-2012, 11:04 PM
MAS96F150's Avatar
1996 Ford F-150
yes the cruise does work. i did notice today that it does have a little bit of a rpm surge when cruising and could most likely use a tune up.
__________________
  #4 (permalink)
Old 04-30-2012, 04:42 PM
MAS96F150's Avatar
1996 Ford F-150
what all sensors control when the converter locks?
__________________
  #5 (permalink)
Old 04-30-2012, 09:32 PM
Lead Head Lead Head is offline
Garage is empty, add now
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
Nothing in particular. Speed sensor, TPS, when the computer decides to really. Those older EEC-IV computers were programmed to unlock the converter very readily for whatever reason.
While cruising, gently tap the brake with your left foot. If the revs suddenly jump, the converter just unlocked.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #6 (permalink)
Old 04-30-2012, 09:41 PM
Blurry94's Avatar
1994 Ford Lightning
Applying the brakes or tuning on the harzards will keep the converter from locking up. Also, a failing converter may not lock up when commanded. However, this normally throws a code.
__________________
Matt C.
  #7 (permalink)
Old 04-30-2012, 09:43 PM
Limp mode also generally forces full line pressure - which you'd certainly feel.
__________________
- Ian
  #8 (permalink)
Old 04-30-2012, 10:52 PM
MAS96F150's Avatar
1996 Ford F-150
If it were in limp mode it would have the CEL on wouldn't it?
__________________
  #9 (permalink)
Old 05-01-2012, 08:46 PM
Blurry94's Avatar
1994 Ford Lightning
Yes and the OD off light normally flashes. However, if the converter wont lock and there is no code,it's possible that the converter is bad: the clutch apply piston has failed. I would first find a way to verify if the ECU is commanding the clutch to lock before replacing the converter.
__________________
Matt C.
  #10 (permalink)
Old 05-02-2012, 12:38 AM
MAS96F150's Avatar
1996 Ford F-150
alright well i believe it is trying to lock because the rpms do rise a lil bit when i just barley touch the brake. so i am assuming it is just old and wore out that it really wont hold anymore... oh well. i do have an oil pan to put on it anyways so ill just search around for a new converter to put in when i get around to the pan. thanks for the help. all is appreciated
__________________
Tags
converter, lighned, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
