Go Back   Ford Truck Enthusiasts Forums > General > Garage & Workshop
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
  #1 (permalink)
Old 04-29-2012, 10:29 AM
4x41977 4x41977 is offline
Garage is empty, add now
4x41977 is starting off with a positive reputation.
Need a new floor jack what brand
I'm looking into buying a new floor jack both of mine just broke. I'm probably going to buy an aluminum one and want to know of a good brand. Thanks
  #2 (permalink)
Old 04-30-2012, 01:04 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
try doing a search on floor jack in this section. There was at least one long discussion.
hj
__________________
ford2go (hj)
No fords left except in my heart
  #3 (permalink)
Old 04-30-2012, 03:00 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
Quote:
Why aluminum? In terms of weight savings- ok, buy strength/reliability/safety, unless you are buying a NSCAR spec unit (which for home use would be $$$$), a steel unit should be great for manys, many years.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #4 (permalink)
Old 04-30-2012, 07:27 PM
Weight savings is the main reason. I have bought two in the past couple years and both have broke.
  #5 (permalink)
Old 05-10-2012, 05:45 PM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is starting off with a positive reputation.
I have 2 Craftsman 3-ton jacks I got them on sale for $70 with tax. Also if you work under your truck/car use stands.
~Gage~
__________________
2005 Ford SuperDuty XLT SuperCab V10 4x4 FX4 Shortbed
2000 Ford Expedition XLT Sport 4x4 5.4L
  #6 (permalink)
Old 05-13-2012, 09:47 PM
therifleman556's Avatar
therifleman556 therifleman556 is offline
Resident simpleton
therifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputation
We just got an OTC Stinger two speed that came with two 6 ton stands for I think the $100-$150 range. Without a load it reaches most jacking points with one or two lever strokes and lifts most things with ease. We've used it for jacking up semi axles too, thought that might be pushing it.
__________________
"If you carry a gun, people will call you paranoid. That's ridiculous. If I've got a gun, what in the hell do I have to be paranoid about?" - Clint Smith
  #7 (permalink)
Old 07-11-2012, 11:29 PM
Samsn4's Avatar
Samsn4 Samsn4 is offline
Samsn4 is starting off with a positive reputation.
i just bought a old Weaver 2ton and rebuilt it, the best i have ever seen.
info
Castle Equipment Co Weaver Jack* Hydraulic Service Jacks and Jack Stands MADE IN USA
my jack
http://www.ford-trucks.com/forums/pi...ctureid=104289
  #8 (permalink)
Old 07-12-2012, 09:40 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I will say if you want to carry the jack in the vehicles much, and aluminum is nice for that. I have one I carry for use when on the road. Otherwise, no reason to turn away from a steel unit, especially when cost is considered. I have some cheapies that lasted years, and others that maybe don't do as well. For shop use I suggest getting the larger 2 1/2 or 3 ton. It is easy to overload the little ones.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #9 (permalink)
Old 07-13-2012, 10:11 AM
Just an FYI- back i the 80's 99% of the commercial service jacks hydraulics were made by a company called ConQuip (IIRR), 100% of their production was in Mexico. While I am not a fan of chinese products, most if not all are coming from there...if I had my personal choice, I would buy "old school" and have it rebuilt, but fora new purchase, I would check out Torin......yeah, I know, although their parts are Chinese made, they are at least assembled and tested in Ontario, Calif.
__________________
  #10 (permalink)
Old 07-13-2012, 11:20 AM
fellro86's Avatar
1978 Ford F-150
I have a Torin that was returned on warranty as it would not stay up. The check valve apparently had some particle holding it open, as I took it home and got it working fine. Where I was working, the warranty stuff just went in the dumpster, so I took it home after it was tossed.
I also have another that was used at a local shop, not sure why they ditched it, but added some fluid to it, and is now one of my best jacks. I have quite a collection these days... I have a low profile Goodwrench bought from Wally world, still working well, and have had it for several years, the one I bought from a discount store over 10 years ago still works, but the frame blew out of it after being twisted a few times. I could maybe save it again, but have enough of them now that I don't need to. I have one other that at this time I don't even recall where it came from, but works well. Want to say ti was tossed from a shop as well, never did anything with it.
__________________
  #11 (permalink)
Old 07-14-2012, 10:28 AM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i have an old snapon 10 ton unit i bought for $25 not working about 10 years ago.
i brought it home and oiled the release lever, then applied a little heat to get the oil to soak in.
it sat in a trailer for 4 years with the lever in the down position and was rusted there.
it works great, but weighs around 500 lbs.
the other 2 are small 3 ton units. one was a no name on it bought at a swap meet 20 years ago for $10, and the other one is a harbor freight i picked up last year for $50 since the release on the no name is acting up.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #12 (permalink)
Old 07-16-2012, 06:04 PM
19fifty4 19fifty4 is offline
19fifty4 is a splendid one to behold19fifty4 is a splendid one to behold19fifty4 is a splendid one to behold19fifty4 is a splendid one to behold19fifty4 is a splendid one to behold19fifty4 is a splendid one to behold
The best one I ever had was a Walker. Wish I still had it - got stolen.
__________________
mike
54 F100
01 F150
Tags
1996, auto, brand, brands, excursion, expedition, explorer, f150, floor, ford, good, jack, jacks, points, required, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
