Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 04-29-2012, 05:18 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Aussie 'Economy' forget MPG, post your Ltr/100km here
Just for comparison purposes, post your ride, drive, and fuel consumption figures here:
F250 4WD 3" lift towing 2 tonnes @ 110kmh: 18.8 ltr/100k (SSSimon) - I've had as low at 15 L/100k running empty and driving easy.
F250 2WD highway Sydney to near Bris-vegas 13.2 ltr/100k (Ratkat)
Anyone else want to share figures?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 04-29-2012, 06:37 AM
xran's Avatar
xran xran is offline
2007 Ford Falcon
xran is starting off with a positive reputation.
Chinstrike
I hate L/100km.... km/L has always made more sense to me because you always know how many k's you've done and when you need to fill up again
No idea what mileage the truck gets, but I fill the tank up to chockas each time I'm home from work and it lasts the whole month I'm home for
__________________
THE YARD - 1994 turbo'd Fairmont 280rwhp @ 6psi, 1994 Ute w/351C SKID PIG, 2007 XR6turbo 433rwhp 11.8 @ 120mph shopping trolley, 1974 F-100 trayback 302C, C4, 9"
  #3 (permalink)
Old 04-29-2012, 06:48 AM
2005 Ford F-250
Right. Just note down the number of k's you get between fills, and divide the number of litres you put in by the number of 100k's you've driven.
e.g. you drive 850 k's between fills and put in 120 litres when you fill to the top.
So 120 (your litres) divided by 8.5 (your 100's of k's) = 14.1 ltr/100k.
Generally 20ltr/100k is pretty thirsty for an F250 (my V8 petrol Landcruser used to use up to 25L/100k towing!!!).
13.2 ltr/100k is the best that I've heard.
__________________
  #4 (permalink)
Old 04-30-2012, 02:09 AM
f100racing's Avatar
f100racing f100racing is offline
1977 Ford F-100
f100racing is gaining momentum as a positive member of FTE.f100racing is gaining momentum as a positive member of FTE.
Feul economy, whats that?
1977 f100 2WD. 351 Clevo,C4, 4.3 gears. On the open, straight road cruising at 80kph, it gets about 16L/100K's. Around the suburbs/city (always results in a little playing) turns to K's/100L!!!
It's good that the servo's are close by, not so good Premium is so expensive.
__________________
351 Clevland,
C4 3500 stall,
4.3:1 Full spool 9"
  #5 (permalink)
Old 04-30-2012, 04:19 AM
2005 Ford F-250
F100racing, I reckon you'd soon fund the addition of a bolt on overdrive unit on your 3 speed with the fuel savings!
Then again, 16L/100k is pretty much what my 4.7 V8 Landcruiser used to get, albeit at 100kmh. So the OD unit would probably just make you 20kph faster for the same 'economy'.
__________________
  #6 (permalink)
Old 04-30-2012, 02:19 PM
f100racing's Avatar
1977 Ford F-100
I have thought about an OD unit but don't really need it.
It only hits the open road once or twice a year. Around the
city i have no need for the motorways.
At the moment i'm saving my a$$ off for a carb,manifold
and new stall. Not sure if thats going to help or make it
a lot worse.
__________________
351 Clevland,
C4 3500 stall,
4.3:1 Full spool 9"
  #7 (permalink)
Old 05-04-2012, 11:42 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
The old F350 (F350 levelled, 4x4, on 285's) got 12.5l/100k when it was babied, and up to 14.5l/100k when it wasn't.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #8 (permalink)
Old 05-08-2012, 05:44 AM
xran's Avatar
2007 Ford Falcon
Chinstrike
hahahaha you don't build a 3.5k stalled C4 with full spool and 4.3's to be economical!!
actually I don't see the point in spending $80-100k on a 7.3L diesel truck the size of the twofiddy if you want economy either, buy a navara for that lol
__________________
  #9 (permalink)
Old 05-08-2012, 05:52 AM
2005 Ford F-250
Agreed xran, but it's worth knowing what's normal and achievable with these beasties !
I'd be stocked if I could get anything below 14L/100km with mine. I'm wondering if I'll see any improvement once I fit my MBRP 4" turbo back no muffler exhaust
__________________
  #10 (permalink)
Old 05-08-2012, 06:53 AM
2000 Ford F-350
My Garage
I wouldn't be surprised if thats possible. Mine had a straight through 4" turbo-back exhaust, and a K&N (it was also a stick shift which helped a little too) and would easily get 14l.
__________________
  #11 (permalink)
Old 05-12-2012, 01:35 AM
Down Under 77 C/C Down Under 77 C/C is offline
1977 Ford F-350
My Garage
Down Under 77 C/C is starting off with a positive reputation.
My 84 F100 4WD with 351 cleveland and 5 speed box gets 17-18 L/100 at 110 klm hour. Round town goes up to 21/21 L100. How's fuel prices, 1.53 per litre here in Nth Queens.
  #12 (permalink)
Old 12-11-2012, 03:50 AM
rnxlf250 rnxlf250 is offline
Garage is empty, add now
rnxlf250 is starting off with a positive reputation.
4.2 RNXL 4WD manual empty, with cruise control on at 95 kmh generaly get 10.95L/100km
Pulling 3 tonne in the gooseneck with the wife and child get generaly 13.5-16L/100km
cheers
  #13 (permalink)
Old 12-11-2012, 05:22 AM
2005 Ford F-250
Good figures for the big unit 4.2 there.
On my 7.3 babying it with the opened up 4" exhaust I managed to get 14.2L/100k on the highway. That's an all time low for my big unit.
__________________
  #14 (permalink)
Old 12-11-2012, 02:13 PM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 is gaining momentum as a positive member of FTE.aussie_f350 is gaining momentum as a positive member of FTE.
I got none for my new truck but;
Last truck 1988 f250 7.3 idi , auto with gear vendor overdrive, 4x4 got 12 liters per 100kms. That's pretty good mixed highway/town, probly a little more highway tho. (Also most efficient out of the 9 f trucks I've owned)
Truck before that was 1991 f350 efi 5.8, 5 speed, 4.11s with 35s, used to get 25-27/100. Was horrible.
Didn't really check any of the other trucks, had a carby 460 one that had gas and had to disconnect the gas for a week to check tanks, and that was by far worst economy I ever got.
__________________
Thanks
Andy
My build thread;
http://www.ford-trucks.com/forums/11...ck-thread.html
  #15 (permalink)
Old 01-07-2013, 04:58 AM
I just did a test, did 656 km for 103 litres, mixed driving mostly highway, and about 50km towing my 20ft caravan! That's with superchip on performance and 6637 and straight 3inch pipe. I haven't worked out litres per hundred yet so can someone? Next full will be real test, towed the caravan 100+ Km, most pretty hard fast.
__________________
Thanks
Andy
My build thread;
Tags
economy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
