Low Boost ??????
Low Boost ??????
Hey guys, I have an early 99 with a 7.3 powerstroke. I finally got my gauges put in. If I on the freeway running 70 mph in over drive I run about 5 pounds of boost. On a wide open throttle run I see about 18 pounds. Thee other day I unplugged the red line on the wastegate on WOT run I only saw about 21 pounds of boost. The truck has the superchips flashpaq and running in performance mode. I know the E99 trucks have a smaller turbo.I've checked theIC tubes and boots for leaks. Is this just the normal amount of boost or what? I really thought I'd see more with the wastegate line off. Any help would be appreciated.
That is about what i am getting..
I see about 3psi at 70
23 boost WOT. Red hose hooked up.
Dp tuner.
With the WW, I lost a few pounds.. With this adjustment i gained it back. https://www.ford-trucks.com/forums/9...ent-video.html
Dp tuner.
derek0525
13
01-19-2016 03:57 PM
