Rebuild small block book - Ford Truck Enthusiasts Forums
Old 04-29-2012, 01:47 AM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Installed a 70 Torino 302 in 65 F100 in the mid 70's. Had the engine rebuilt in the later 90's. After 20 K cylinder wall cracked on the rebuild due to driver error. Rather than sleeve the 1 cylinder I purchased a created 68 302 approx. 6 yrs ago. Couple days ago the truck started running poorly, missing at low rpm and stalling at a stop. Went thru the basic tune-up procedure; turned engine over to the top of compression stroke and found the timing marks were approx. 30 degrees, or more, off. After rotating distributor gear to align with timing marks still could not get the engine to idle. At this point noticed a major vacuum leak. Compression tested and found #2 cylinder running about 1/2 what the other 7 at 150 vs 90. Suspect valve problem since there was no improvement when I squirted oil into the cylinder.
Not an authority but it would seem to me, regardless of how serious a vacuum leak, at the top of the compression stoke the timing marks should be on or about TDC.
Which brings me to my question, once the problem has been diagnosed I would like to remove the head(s) from the 68 and make the repairs. In the meantime, could I use the heads from the Torino on the 68 289/302. Also, I would like to save some serious buck and break the Torino engine down and take the block in and have the sleeve installed. I am not familiar with rebuilding engines. I was browsing thru a 'how to rebuild Pontiac engines' and very impressed with the amount of detail and numerous pic's. It's a "SA design" with a workbench format. I came across a similar 'how to' on Ford small block engines with the same SA design and workbench format but from what I could observe online it did not appear to have anywhere near the amount of detail and pic's as the other book. Thought I would check and see if any member(s) could recommend a book. Comments and suggestions appreciated!!
Old 04-29-2012, 12:09 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yes you can use the Torino heads on the '68 but if these heads have different rocker types you have to pay attention to pushrod length.. may need custom rods.
Rebuild Small-Block Ford Engines HP89: Amazon.ca: Tom Monroe: Books
Old 04-29-2012, 01:08 PM
In reviewing the above noted book it appears it is simular to the "SA Design" book but different authors. I will check with local book store and see if any carry both books for comparison. Appreciate the informatlion!! Thank you!!
Amazon.com: How to Rebuild the Small Block Ford-Color Edition (SA Design) (9781932494891): George Reid: Books
Old 05-02-2012, 10:10 AM
Flathead Red's Avatar
Flathead Red Flathead Red is offline
Flathead Red is starting off with a positive reputation.
I bought the HP books version on Amazon used for $8. Well worth it. It was written a while ago but that info hasn't changed a bit.
Red
Old 05-02-2012, 12:49 PM
Quote:
Red
Ordered the book, short version, don't have a clue, went thru and replaced components for a tune up, swapped carbs and now the engine does'nt run at a constant rpm but surges; anyhow, it appears I am going to need the book. Thanks all appreciate the recommendation.
New Y-Block Book Y-Blockhead Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 04-14-2014 09:50 AM
400ci Rebuild Literature........ taneum 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-17-2013 01:15 PM
428 Questions BlueOvalfan85 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 21 11-04-2007 05:38 PM
77' 351 W m350 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 09-27-2005 09:04 PM
My Torino 72429torino Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 03-24-2005 04:18 PM
Tags
30, 302, 50, 68, block, book, degrees, engine, engines, ford, marks, rebuild, review, small, timing, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
