1985 Ford f250 is dead
I have a 1985 ford f250 and it is dead. I replaced the battery, solenoid, ignition switch, and checked the fuses. The ****ing thing is still dead. I know the starter is good. When I turn the key I get nothing no lights no click no whirring, nothing. At first when I changed the battery I hooked it up wrong stupid I already know. I don't know what else to check on this thing.
on
Sounds like you blew a fusible link. I don't know where they are for sure. It's a rudder thing kinda over the wire with like fuse in raised letters on it. Generally under the hood just of the solenoid. Anyway that's my guess.
We could use a little more info as it may be any o several things.
Like what engine and is it carbed or injected?
Does it have a computer if injected?
Yep it was probably just that fuseable link the whole time. Once I got that replaced I had to hook it up to the positive terminal on the solenoid now it is running like before. What a pain in the ***. Thank you for your help.
applebaggins
18
09-20-2017 02:02 PM
hinterlander
11-08-2008 09:12 AM
dadsford
09-16-2008 08:04 PM
acbruno1
04-10-2006 10:02 PM
