94 5.8 running hot
Old 04-28-2012, 11:33 PM
edo488's Avatar
edo488
edo488 is offline
94 5.8 running hot
1994 f150 xlt 5.8l 2wd
temp is in normal range most of the time. when at highway speeds/2500 to 3000 rpm temp gauge is almost to the red line. Moves around a little at the last white line and back to the L in "Normal" and sometimes back close to the red line. Not loosing fluid. Have changed the thermostat twice with last one from Ford. I can see the thermostat open and temp drop on the gauge when running around in town. Would not think fan clutch is the issue because its at speed when I have the issue. What should I check for? Any thoughts?
Old 07-26-2012, 06:35 PM
f2504x4man's Avatar
f2504x4man
f2504x4man is offline
Did you ever figure this out? I'm having this exact problem and have replaced the whole cooling system but the heater core. 92 E250 5.8
Old 07-28-2012, 10:18 PM
edo488's Avatar
edo488
edo488 is offline
no.
oddly enough my temp problems only occur in the winter and spring, and not all the time. runs on low end of normal now that its 100 degrees outside.
Old 02-09-2014, 02:27 PM
edo488's Avatar
edo488
edo488 is offline
FYI this was repaired. Random overheating was from timing cover leak. Air getting sucked in or trapped was causing the problem. Runs on the low end of "Normal" now. Replaced water pump and timing chain while it was opened up.
Old 02-09-2014, 07:00 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Thanks for updating this! Glad to know you found and fixed the problem.
aharleycpl
12-31-2015 10:35 AM
tylerz71
12-26-2014 03:55 PM
tucan69
01-25-2008 01:23 PM
proteks
17
12-14-2004 12:35 PM
momofcrts
Aerostar
08-26-2003 06:10 PM
Quick Reply: 94 5.8 running hot
