'08 F150 STX: Trans bumps hard as it starts from a dead stop.
Old 09-17-2012, 08:17 PM
gregghendrix's Avatar
gregghendrix
gregghendrix is offline
My truck started bumping (like it is going into gear) from a dead stop about 6 months ago. I have checked everything external to the trans that I can. Today I thought about foot braking and accellerating. It seemed to shift into gear with a bump, I let off of the gas and brake and accellerated normally, and it did not bump. Does anyone know of similar problems with this type of eng/trans combo (4.6 Auto)? I do service the vehicle well, and the trans shifts great after it starts off. Any help would be appreciated.
Old 09-18-2012, 07:25 AM
Cofcmsc's Avatar
Cofcmsc
Cofcmsc is offline
Gregg
Are you sure that it is the tranny? Could it be the slip yolk on the drive shaft. This is a known issue for ford trucks. I thought I had a bad engine mount or something on my 06' 2wd. On mine the bump only happens from a stop. Leaving the line the truck squats shortning the drive shaft at the yolk and at the same time you are appling torque, the result is a momentary binding and release(bump). It is not like a slipping tranny has a very solid feel to it. Hope that is what it is on yours. If you look at the shaft there is the area with a rubber boot that is where I had the issue. I dropped my drive shaft from the rear diff with the intention of greasing mine, but could not figure how to get into the thing, I stroked mine back and forth a few times to spread the existing grease around and bolted it back up (4 13mm bolts). The problem disappeared for about 50k miles. now it's back but I know what it is and it is not a big deal.
Old 09-19-2012, 07:38 PM
gregghendrix
Yeah that sound just like what mine is doing. I'll check the slip yoke and see what I find. Thanks a bunch.
Gregg
F-erOnlyRunsDwnhill
04-11-2014 09:20 PM
eric72xlt
08-15-2011 11:13 AM
ken's 80
01-23-2007 11:21 AM
Hsi95
03-31-2004 11:54 AM
Quick Reply: '08 F150 STX: Trans bumps hard as it starts from a dead stop.
