Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 04-28-2012, 09:16 PM
chato86f150 chato86f150 is offline
Garage is empty, add now
chato86f150 is starting off with a positive reputation.
Transmission not shifting properly
Transmission will not shift into 2nd gear until it reaches 30-35 MPH, and even then you have to get off the gas for it to shift. The engine is a freshly overhauled FI 302, so I dont' want to stress the engine till it has had to break-in. Any help would be great.
  #2 (permalink)
Old 04-28-2012, 09:35 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
FTE OK Chapter Ldr
Gary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to behold
Can't offer any assistance. No clue what transmission it is. We don't guess 'cause we'll give you bad info. Please tell us everything that is going on, like what transmission, how long it sat w/o driving, and any mod's you've done to the tranny.
__________________
Dad's '81 F150 Ranger XLT 4x4 w/a 351M sporting an RV cam and Performer carb & intake/ZF5/3.50 gears w/Kevlar clutches in the rear LS, and sitting on 30 x 9.5 Starfire's wrapped around aluminum bullet holes
  #3 (permalink)
Old 04-28-2012, 10:25 PM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Quote:
This ^^^!
If we don't know what it is, we can't help you. A fuel injected 302 doesn't tell us whether or not your 302 came with a C4, a C6, or an Automatic Overdrive.
If it's a C4 or a C6 it could be the modulator valve or the way the vacuum lines might've been (incorrectly maybe?) installed.
If it's an Automatic Overdrive, you might need to adjust the linkages that control the shifting of the transmission (and also serve to keep the transmission from burning itself up).
If you know what transmission you have, tell us. If you don't, you're going to either have to tell us the transmission code on your door jamb sticker, or you're going to have to get up under there and count transmission fluid pan bolts to tell us.
Let us know what you find and we can help.
  #4 (permalink)
Old 04-28-2012, 11:13 PM
Agree, I will check it tomorrow and get back with you all, the truck did sit for over 3 years
  #5 (permalink)
Old 04-29-2012, 07:46 AM
Gary Lewis's Avatar
FTE OK Chapter Ldr
Quote:
See, you've already started to help. We can work in the dark, but our answers will be very suspect and might include phrases like "push in the clutch and shift gears" if you don't tell us what tranny you have.
But, the thing about sitting, which I suspected, is likely a big part of your problem. I'll save my response to that until you report back with more info, but please tell us everything and then some. We'll discard the irrelative bits.
__________________
  #6 (permalink)
Old 04-29-2012, 09:43 PM
It says automatic overdrive metric, it has 14 bolts, it's shifting now after a good drive, but it stills shifts hard, and it seems to sprudder also, doesn't have the power you think a rebuilt engine would have. Any advice on how to get it have more power?
  #7 (permalink)
Old 04-29-2012, 10:03 PM
Gary Lewis's Avatar
FTE OK Chapter Ldr
AOD tranny. Since it sat for over 3 years you have varnish or somesuch in the passages. I had a similar problem on a C6 and cured it by putting half a bottle of Sea Foam Transmission stuff in it - and then drove it, and drove it, and drove it. Took about 500 miles to completely straighten out.
As for the engine, you are back to doing the "please tell me the answer without any clues" thing again. In order to discuss power we need to know what gear ratio you have, what tires you are running, and what's been done to the engine. Further, you will need to pull the codes from your computer as it'll tell you if anything is wrong. Here are a couple of links on that: Pull Codes 1
Pull Codes 2
I'm sorry if I sound gruff, but you don't seem to get it very quickly. We want to help you, but we cannot give you decent answers without understanding the problem. Please do not ask another question without giving us the detail. And it would be highly preferable if you would give us the results of pulling the codes in your very next post.
__________________
  #8 (permalink)
Old 04-30-2012, 01:36 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen is gaining momentum as a positive member of FTE.Ken Blythen is gaining momentum as a positive member of FTE.
Also, regarding the power - if the engine is still very newly rebuilt it will be tight, giving a 'resistant' feel driving.
All the engines I have rebuild & run-in have felt this way, then after a period you realize that resistance has (quite suddenly sometimes) gone, & the engine feels a lot freer.
You can then also get a better tune up on the engine.
__________________
1983 F250 XLT 2WD, 351W, T19, 3.54 Dana 60
1983 F150 302, T18, 3.55 8.8, Supercab - parts truck
1941 Ford 1 Tonner - deceased
1942 GMC CCW-353 6x4
  #9 (permalink)
Old 04-30-2012, 07:43 AM
Pull Codes 2
Inappreciate it, and I understand about needing more info, I apologize. I will run the VIN through the LMC VIN identifier. I will drop some sea foam in it as well, since I plan on dropping a can in the gas tank.
  #10 (permalink)
Old 04-30-2012, 07:45 AM
Quote:
Originally Posted by Ken Blythen View Post
Also, if the engine is still very newly rebuilt it will be tight, giving a 'resistant ' feel driving.
Makes sense, what would be a better tune up? Would it be adjusting the timing?
  #11 (permalink)
Old 04-30-2012, 07:57 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
On the EFI 302 w/AOD, there is a transmission TV (throttle valve) cable at the throttle body. It is adjustable, but be very careful, this is a 26 year old plastic housing! The cable core is pulled by the throttle linkage, if you are getting late, hard shifts, you need to unlatch the clip that hold the casing and move the casing toward the lever by one notch and relatch it. DO NOT GO A LARGE AMOUNT!! To far will make it slip and ultimately burn up your transmission.
Timing, if you haven't checked it since installing the engine, yes, it should have been set as soon as you warmed it up the first time. For all who need it, TFI distributors, if you set it so that the leading edge of the shutter is just at the center of the Hall effect pickup you will be almost dead on when you check it with a light.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #12 (permalink)
Old 04-30-2012, 08:02 AM
Gary Lewis's Avatar
FTE OK Chapter Ldr
IIRC, you don't even get to set the timing on those engines. That's set by the lobes on a star reluctor that is pressed into the harmonic balancer and picked up by a coil in the timing pointer. So everything, and I mean EVERYTHING, is done by the computer. That is why it is necessary to pull the codes to see what the computer thinks. Everything may be ok, but if not the computer could be in limp-home mode and you will not have reasonable power. The computer knows and you need to find out.
Edit: I forgot you can turn the distributor. Duh!
__________________
  #13 (permalink)
Old 04-30-2012, 08:28 AM
Timing has been set to the factory spec, but I thought maybe there was something like advancing it to maybe make it perform a little beter.
  #14 (permalink)
Old 04-30-2012, 08:56 AM
Gary Lewis's Avatar
FTE OK Chapter Ldr
You can advance it some. But you really need to know that the computer is happy FIRST. If it isn't happy is is probably not advancing the timing at all, IOW limp-home mode.
__________________
  #15 (permalink)
Old 04-30-2012, 12:30 PM
Sorry - I was thinking this was a carbed HO motor from a different thread.
So as Gary says, the computer & EFI will be looking after tuning.
__________________
Tags
2000, 73l, 85, f150, ford, gears, identifier, idi, lmc, metric, modulator, overdrive, properly, shifting, shifts, suddenly, transmission, valve, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
