1994 F150 ignition problem - Ford Truck Enthusiasts Forums
Old 04-28-2012, 10:13 PM
joe0854 joe0854 is offline
joe0854 is starting off with a positive reputation.
Hello
I have a 1994 F150 XL 4.9 that runs but won't start with the key. I am able to start the truck by jumping the selenoid which tells me the starter is ok.
I recently replaced the ignition switch and selenoid and was wondering if there was anything else to look out for. The truck has been sitting for about 10 years and was started for the first time today and it runs like a champ.
When i do try and start it with a key, all i hear is a clicking sound coming from behind the dash. Any help would be much appreciated.
Thank you
83 won't start Kwill 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-19-2016 11:21 PM
desperately needing help colvin420 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-18-2015 07:26 AM
Need help with everything!!!! 95fordbroncofullsize 1978 - 1996 Big Bronco 2 10-26-2014 12:28 AM
issues with starter and selenoid westbrooka1 1987 - 1996 F150 & Larger F-Series Trucks 22 07-24-2014 08:44 AM
Bad neutral safety switch? llee 1987 - 1996 F150 & Larger F-Series Trucks 3 04-08-2009 06:15 PM
Tags
1994, 94, 96, f150, ignition, switch, trouble, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
