Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-28-2012, 05:12 PM
RFAgrasshopper's Avatar
RFAgrasshopper RFAgrasshopper is offline
1927 Ford T
RFAgrasshopper is starting off with a positive reputation.
Question Lincoln Y Blocks what parts interchange?
Have always played with 4,6and small(Windsor) V-8's. Don't have any info on Y-blocks and so I know Lincoln had the 317,341 and 368 engines. Will intakes or exhaust manifolds made for the Ford Y blocks fit the Lincoln engines?Are all the Lincoln engines hyd cammed? What are the main differences between the Lincoln engines and the Ford engines.
  #2 (permalink)
Old 04-30-2012, 06:52 PM
312 312 is offline
Garage is empty, add now
312 is starting off with a positive reputation.
oil pump is only thing that interchanges
  #3 (permalink)
Old 05-01-2012, 12:15 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is online now
HT32BSX115 is gaining momentum as a positive member of FTE.
Quote:
Yeah. Not much interchanges. The parts availability is also worse for a Lincoln-Y Home
__________________
1955 F-600/292Y/E4OD // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!!
1947 Stinson 108-2 Station Wagon, Franklin 6A-335B
1987 Four Winns 211 Liberator, 1997 Mercruiser 454/Bravo III
(RESISTANCE IS FUTILE) 73 de Rick
  #4 (permalink)
Old 05-01-2012, 03:49 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.
The rocker arm stands will work on either motor.
  #5 (permalink)
Old 06-06-2012, 09:05 AM
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
That's interesting about the rocker arm stands. Rocker arms and pushrods are different?
  #6 (permalink)
Old 06-06-2012, 03:31 PM
I do believe the rocker arms and pushrods are different.
The Ford stands have the hole for the shaft in the center. The Lincoln stands have the hole slightly off center. On one side it places the shaft at the same height as the Ford. On the other side it places them a little higher. Useful for getting the valve geometry dialed in. But shims are often needed despite the stands used so it's not much use to scour the earth for a set of Lincoln stands. It's just one of those things to get if you come across them because you "might use them one day"
Mummert sells new aluminum stands with the hole off center.
  #7 (permalink)
Old 06-06-2012, 08:15 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Charlie is right, the rocker arms are off center compared to the Y. I bought a NOS set that was supposed to be for the 239-312 series, but it was for the lincolns. Ditto on the stands also. The adjusters and nuts are the same as we use.
__________________
Mike Southern Oregon
1946 1/2 ton with Y-block, '62 Mercury Meteor S-33, '55 Ford Country Sedan wagon, '64 Falcon Futura, '90 Ranger 4WD, '54 Ford model 600 tractor
Tags
2005, 2008, 368, 42, block, differnece, exhaust, ford, interchange, lincoln, manifold, panels, parts, transmition, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
