Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- How to Replace a Cracked Windshield
Step by step instructions for do-it-yourself repairs
Windshield frame rust from leaky seal
Its really bad along the top, I've dealt with it for 2 years because the paint was still in tact but now the paint is starting to peel up and that just makes the rig look like junk.
I'll try to get some pictures if I can, I don't do much body work so I'm sending it in to a body shop but I work a lot and don't know if I'll be able to make it to the shop midway.
on
You could how ever heat it up in areas carefully with a heat gun, hair dryer and lift it up some to have a look.
Sometimes this will take it off the glass edge in areas tho, as the factory applied method is not the greatest, but if you are careful you should be able to look under the rubber part of it in places.
Tugly
25
12-12-2018 10:34 PM
