Old 11-20-2014, 06:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Windshield frame rust from leaky seal
Old 04-07-2014, 10:30 AM
04fivefour's Avatar
04fivefour
04fivefour is offline
Originally Posted by Bigpipes 35
Is yours as bad as the OP's ??
Its really bad along the top, I've dealt with it for 2 years because the paint was still in tact but now the paint is starting to peel up and that just makes the rig look like junk.
I'll try to get some pictures if I can, I don't do much body work so I'm sending it in to a body shop but I work a lot and don't know if I'll be able to make it to the shop midway.
Old 04-08-2014, 12:16 AM
wallz's Avatar
wallz
wallz is offline
Originally Posted by BEARDOWN
Anyone know if I pull that seal off around the windshield of to take a look under it, does it just push back on?
No, they come attached on the stock windshield.
You could how ever heat it up in areas carefully with a heat gun, hair dryer and lift it up some to have a look.
Sometimes this will take it off the glass edge in areas tho, as the factory applied method is not the greatest, but if you are careful you should be able to look under the rubber part of it in places.
Old 04-14-2014, 12:49 PM
04fivefour's Avatar
04fivefour
Well I dropped her off today. We'll see how it turns out and I'll try to get some pictures.
Old 04-15-2014, 08:19 PM
neilc88's Avatar
neilc88
neilc88 is offline
Good question. I am wondering the same.
Tugly
25
12-12-2018 10:34 PM
sr23
05-04-2014 03:09 PM
Potlicker David
04-25-2013 03:33 PM
P Munson
09-24-2010 06:03 AM
ATC_250SX
05-09-2005 09:56 PM
Quick Reply: Windshield frame rust from leaky seal
