Engine 351M/400, need to understand
Hi all from Quebec, kind of newbie question. I bought a 1977 F-250 camper 2X4, 18000 or 118000 miles dont realy know, realy like it ! I try to understand the meaning of 351m/400. My vin number told me I have a 400, last owner tel me he think i'ts a 351, there is a sticker on the right valve cover (8 bolts) with this information: 351M/400 EGR
Engine displacement 400 CID
So I think it's a 400 but wy they write 351M/400 ???
I dont realy care wich one I have but I whant to order the right parts, at Rock Auto for example. Sorry for my bad english, JF
You probably have a 400 if its unmolested. They wrote 351m/400 because that is the engine family. It's from ******* child of the 335 engine family, but still a cleveland. I love em, but then again I love the underdogs like clevelands and mopars.
The only way to know 100% for sure is to pull the number off the crank and see.
Absolutely everything is the same, except for pistons and crank and depending on the year, the flywheel. And if you really wanna get into it, carb adjustments. Other than that its the same.
You can't accurately measure the stroke through the spark plug hole due to the angle. Most accurate way to check is look for the number on the crank.
For refrence, a 400 has a 4.00" stroke, a 351M has a 3.50" stroke
I've got a '78 with a 400. Its fairly low mileage and in decent shape so I'm not in a hurry to get into the engine. When I do, there is lots that can be done to increase power and efficiency. 50-100% power increase isn't too hard. Stages or steps as I have learned:
1. Cam, timing set and 4 bbl carb. This straightens out retarded cam timing, updates a worn chain and gets it breathing.
2. Rebuild with stock type heads and higher compression piston.
3. Rebuild with closed chamber heads (Austrailian Ford iron heads or aftermarket) and higher compression piston.
TMeyer sells the pistons and other parts needed for upgrades.
redneckpride99
10-18-2002 09:35 PM
