steering wheel adapter? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-10-2012, 01:22 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Originally Posted by AXracer View Post
If I was going to do that much machining, I'd make it so the two pieces could be bolted together rather than needing welding, heat and plastic doesn't coexist very well.
LOL yeah very good point! I haven't put much thought into it yet...I guess that shows..?
When the day comes, and I am focusing on the steering wheel...that should be a good day! I wonder what year that will be?
Thanks AX !
Old 11-02-2012, 07:45 PM
seaves46 seaves46 is offline
seaves46 has a good reputation on FTE.seaves46 has a good reputation on FTE.
Guys i've just bought the grant boss kit for my 56 .
Grant kit is number 4257 , and i have confirmed with Grants it's the correct one .
My question is has anyone had any trouble actually fitting the boss to their column ?
It is way to tight , and it doesn't even go on far enough to fit the retainer nut .
The spline on my column is ok , and i have actually tried it on a 53 column as well , but to no avail .
The only way i could get it on is to bash it on using a BIG hammer , and i'm not going to do that .
Any ideas ?
Old 01-28-2014, 12:10 PM
hillcogolfer hillcogolfer is offline
hillcogolfer is gaining momentum as a positive member of FTE.
Wondering whether you ever found something satisfactory to work? My application is a '50 Ford F1 with stock column but it has a little (13 inch)Grant wheel that somebody put on a long time ago. I just want a bit larger diameter wheel so in looking I see all kinds of different bolt patterns....3, 5, 8, etc....the little Grant wheel I have on now has a 8 bolt pattern....but I don't know what adapter I need....except guys on here are saying on the one hand a Grant # 4257 adapter/kit is the one for Ford F1 trucks but then on the other hand say that these don't fit worth a crap. Any feedback from you side?
Old 01-29-2014, 11:12 AM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
Quote:
Originally Posted by jonf View Post
What adapter do I need to put after market steering wheel on my 52 F1?
Have some in the spare parts box you can have for the shipping cost . Send me a PM & let me know . Later , Denny
Old 01-29-2014, 03:57 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Quote:
If you aleady have a Grant wheel mounted, you must already have an adapter. Look at the wheel bolt pattern. I'm using a Grant 15" banjo style wheel.
9 bolt hole steering wheel jerryst 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-15-2017 02:14 PM
WTB Steering wheel adapter steuspeed Ranchero & 1961 - 1967 Econoline 0 07-21-2016 12:01 AM
Aftermarket Replacement Steering Wheel FREDDAY 1987 - 1996 F150 & Larger F-Series Trucks 2 01-29-2016 12:44 PM
1963 Econoline pickup Jon P. Ranchero & 1961 - 1967 Econoline 10 07-15-2015 01:28 PM
steering wheel adapters ZOOT 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-13-2013 03:08 PM
Tags
1956, 1967, 1973, 2008, adapter, adapters, f100, ford, fords, grant, installation, kit, steering, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
