Customer Satisfaction program 12B33 - Ford Truck Enthusiasts Forums
Old 04-27-2012, 08:53 PM
OPTITRADER66 OPTITRADER66 is offline
OPTITRADER66 is starting off with a positive reputation.
I recieved a letter today on my 2011 f-350 superduty
Customer satisfaction program12B33.
letter states,
On your vehicle, the Nitrogen Oxide [nox] sensor in the exhaust system may become inoperative and cause the check engine light to turn on. If the nox sensor is inoperative,engine power may be reduced under some conditions.
Then it states that they will reprogram the pcm and nox module and if necessary replace nox sensor free of charge until April 30,2013.
Just wondering if anyone else recieved this letter.
Old 04-27-2012, 09:09 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
letter states,
Also received one.
Sam
Old 04-27-2012, 09:11 PM
sandyc sandyc is offline
sandyc is starting off with a positive reputation.
I received the same letter today. Have no idea what it means. Guess I'll call my dealer next week and find out. My truck runs perfect and always has.
Old 04-27-2012, 11:50 PM
Fontana Fontana is offline
Fontana is gaining momentum as a positive member of FTE.Fontana is gaining momentum as a positive member of FTE.
I just got it too! See PCM post
Old 04-27-2012, 11:54 PM
hschiro's Avatar
hschiro hschiro is offline
hschiro is starting off with a positive reputation.
I just received one today in the mail. I have read a lot of people on this site having nox sensor problems / replacements so I think I will get it done soon. Must be a fairly common or a bigger problem than we may know if they are sending out all these letters IMO.
Old 04-28-2012, 12:57 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Received mine also.
Dealer had sent me their own notice a week or two ago.
Old 04-28-2012, 04:27 AM
Nipperdog's Avatar
Nipperdog Nipperdog is offline
Nipperdog is gaining momentum as a positive member of FTE.
Got one of those today. It says that the procedure could take half a day to complete. It is due for a service in June so they can do the recall at the same time.
Old 04-28-2012, 06:40 AM
KA9DAL's Avatar
KA9DAL KA9DAL is offline
KA9DAL is starting off with a positive reputation.
Got one also, mine is scheduled in next Fri for other things, so I will see if they can do it then.
Old 04-28-2012, 07:26 AM
Big-Sarge's Avatar
Big-Sarge Big-Sarge is offline
Big-Sarge is gaining momentum as a positive member of FTE.Big-Sarge is gaining momentum as a positive member of FTE.
I got the same letter yesterday. I read a post on here by "M-Chan68" that said on one particular truck he worked on reprogramming the PCM to the latest calibration failed to fix the NOx sensor from tripping the CEL...and the end result was to replace the NOx module to finally repair the issue. My truck is schedule to go into the dealership this Friday, I am bringing a printout with "M-Chan68" comments and see what the mechanic says..I will post the outcome.
Old 04-28-2012, 10:20 AM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
All of you who received this letter, I did too BTW, have you previously had your PCM updated that includes the new calibrations that also contains a change to where the lighting of the Water In Fuel indicator is now stored?
I have not got my truck's PCM updated to where the WIF indicator is now something retained in memory. Not trying to be too pessimistic on this...more so curious.
Old 04-28-2012, 05:16 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Got mt letter today, it said the recasll is good untill April 2013. I am not having any problems yet so I think I will let yall get your updates first to see if there are any negatives before doing the update.
Opinions???
Old 04-28-2012, 05:18 PM
rrthor rrthor is offline
rrthor is starting off with a positive reputation.
I too received the same letter this Friday. I never had a check engine light come on. The truck is 2011 with a build date of 11/3/10 and the truck now has 11,000 miles on the odo. The only problem I have had is 2 shift flares between 4000 and 7000 miles and those were fixed with TSB 11-4-21 done on 7/22/11.
Old 04-28-2012, 05:26 PM
smallcandle smallcandle is offline
smallcandle is starting off with a positive reputation.
Quote:
Opinions???
Got the same letter today and I was thinking of holding off also. Curious to see the experiences of other members first.
Old 04-28-2012, 11:07 PM
buckmasters's Avatar
buckmasters buckmasters is offline
buckmasters is starting off with a positive reputation.
I got my letter today and am holding off for a while. I'm at 23K miles, no CEL's and no shifting issues. I guess my question is does this update just go after the NOx sensor issue or does it capture all of the other flashes as well? I have no desire to do any flashes if my truck is running fine.
Old 04-28-2012, 11:28 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
I got mine today as well. I've got to get the truck in next week for some shifting issues so I'm going to ask the tech about it then.
Thoughts on NOX sensor and DEF reservoir heater WVSTROKE 6.7L Power Stroke Diesel 3 08-05-2016 08:01 AM
Customer Satisfaction Program 15N05 tseekins 2009 - 2014 F150 11 02-25-2016 10:21 AM
Customer Satisfaction Program 15M01 Traveling Man 6.7L Power Stroke Diesel 1 06-04-2015 08:28 PM
recall 12b33b question 11red250 6.7L Power Stroke Diesel 8 06-20-2014 07:42 AM
Another Pleasant Experience at my Dealership (Koons Sterling Ford) Jimax 6.7L Power Stroke Diesel 1 05-01-2012 10:52 AM
Tags
12b33, 2011, customer, exhaust, f350, faulty, forf, nitrogen, number, oxide, program, recall, satisfaction, sensor, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
