Customer Satisfaction program 12B33 - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 05-01-2012, 06:12 AM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Yes there is a date associated with trucks built in 2010. I think my advisor said Nov. Anything before gets it, any truck after doesn't.
  #47
Old 05-01-2012, 09:17 AM
7.399 7.399 is offline
7.399 is starting off with a positive reputation.
Quote:
I have a 2012 with a build date of August 2011 and I got mine in the mail on Saturday.
  #48
Old 05-01-2012, 10:58 AM
wagdaggy wagdaggy is offline
wagdaggy is starting off with a positive reputation.
I just had mine done yesterday, along with oil change and fuel filters, only have 14k on truck but dealer said Ford recomended them replaced at 15k so I had it done. Only had a 25 mile highway drive home but noticed a increase in mpg. I usually ran 16.5 to 18 at 75, it showed 21-23. Truck also shifted smoother. I am going on a trip later this week pulling a boat so I am courious to see if there is a real gain or if yesterday was a fluke.
  #49
Old 05-01-2012, 11:25 AM
Jimax Jimax is offline
Jimax is gaining momentum as a positive member of FTE.
Just had mine done. Here is the language off the ticket:
Recall 12B33
Checked for NOX Codes - None - Recalibrated - PCM, TCM, NOX Modules.
Zero change in drivability. Transmission is re-learning shift patterns, but that's nothing special. Engine noise the same, MPG seems to be same as well.
  #50
Old 05-01-2012, 12:17 PM
srkr srkr is offline
srkr has a very good reputation on FTE.srkr has a very good reputation on FTE.srkr has a very good reputation on FTE.srkr has a very good reputation on FTE.
Job 1 here...stumbled across the update almost 2weeks ago...it letter Saturday.
Had my oil changes 2 weeks ago this Thursday...had the update done then. No change,..sill runs great..towed over 500 miles since and driven a lot more including over 4 hrs of just idling.
No worries,..get it done.... I trust Ford knows more about these trucks than I do.
Still whistling.
Shane
  #51
Old 05-01-2012, 03:56 PM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
I must be getting old. I remember when a recall on a vehicle, or part thereof, was called a "recall", not a "Customer Satisfaction Program"
I didn't read it real close but it looks like we get free Nitrous oxide systems or something . Wow...even more power!
  #52
Old 05-01-2012, 10:42 PM
shadowSVT shadowSVT is offline
shadowSVT is starting off with a positive reputation.
Mine was done when it was in having the fuel pump replaced a couple weeks ago.
I haven't noticed any difference.
  #53
Old 08-04-2012, 11:46 AM
summet20's Avatar
summet20 summet20 is offline
summet20 is starting off with a positive reputation.
Build date of June 2010. Had problems with the NOX around spring of 2011, they were replaced shortly after. Just received a notice from a dealership with this code 12B33. I dont think I will be getting it done since it has nearly 70,000 miles and no troubles or codes. It runs and drives fine with no issues, so I think i'll take my chances this time around. However one thing that does come to mind is make sure everybody watches their radiators for leaks! It will happen its just a matter of when.
  #54
Old 08-13-2012, 11:28 AM
mwierowski mwierowski is offline
mwierowski is starting off with a positive reputation.
I just had this done a couple weeks ago because the CEL came on at around 78k miles with P164A as the code. They replaced the NOX sensor per the TSB and updated to the latest flash on the PCM, ECM and TCM. I previously had transmission flare issue and had that resolved via TSB 11-04-21. Just finished putting 2k miles of towing about a 6,800lb load with the truck and I think the latest TCM update is smoother shifting than the flash from TSB 11-04-21. My fuel mileage hand calculated hasn't changed (I run this same trip once a month for work, so I got the same over all average I always get pulling the same load) and over all the truck ran great. The truck only went into regen twice over the entire trip, which is pretty typical as well.
-Mike
  #55
Old 08-13-2012, 12:03 PM
Native Tex Native Tex is offline
Native Tex is starting off with a positive reputation.
I have a 2012 that was bought July 5th, build date April. I suppose I will get a letter as well. I notice most who have the letters are 2011 models; wonder if the later build models have had the NOX issue corrected?
  #56
Old 08-13-2012, 09:46 PM
army350's Avatar
army350 army350 is offline
army350 has a great reputation on FTE.army350 has a great reputation on FTE.army350 has a great reputation on FTE.army350 has a great reputation on FTE.
I bought my 2012 F350 in April (build date Nov 11) and the dealer performed the updates before I took delivery. They told me that they perform the updates as they are released even when the vehicles are sitting on the lot.
  #57
Old 06-19-2014, 09:51 AM
Plumangy Plumangy is offline
Plumangy is starting off with a positive reputation.
NOX nightmare
Riding down the road not a worry in mind in your King Ranch Super duty diesel and the displays says Emergency Stop engine shutdown...your power reduces so you pull over and then the engine is shut off ...you are now stranded on the side of the road....no matter what time of day or what neighborhood your driving through. Imagine if your wife is driving with your kids in the truck. Your only option call a tow truck and bring it to a repair shop. This has happened to me twice first at 31k miles and yesterday at 60k miles. Of course the second time it was outside the warranty period and the dealership (Maroone in Margate Fl) speaking on Fords behalf says tough nuts buddy and oh by the way there are four of these wonderful sensors so be prepared to have it happen to you multiple time in the future. So a known defective exhaust sensor in a 60k truck will leave sitting on the side of the road and Fords response is SFY... Need to re-think my purchases from now on.
  #58
Old 06-19-2014, 09:58 AM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Plumangry, welcome to FTE! I'm certainly not glad to see the circumstances for you posting and understand how you feel. I hope you are fixed up and back on the road soon. GM, Ram and Ford all face these emission sensor challenges. It's one of the my biggest concerns with the new emission standards that were crammed down their throat by the EPA and forced the consumer to become beta testers and financially contributing at that. I chose not to participate.
  #59
Old 06-19-2014, 01:09 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
Quote:
#1 you had an egt sensor go bad, not a nox sensor (theres only one of those)
Thoughts on NOX sensor and DEF reservoir heater WVSTROKE 6.7L Power Stroke Diesel 3 08-05-2016 09:01 AM
Customer Satisfaction Program 15N05 tseekins 2009 - 2014 F150 11 02-25-2016 11:21 AM
Customer Satisfaction Program 15M01 Traveling Man 6.7L Power Stroke Diesel 1 06-04-2015 09:28 PM
recall 12b33b question 11red250 6.7L Power Stroke Diesel 8 06-20-2014 08:42 AM
Another Pleasant Experience at my Dealership (Koons Sterling Ford) Jimax 6.7L Power Stroke Diesel 1 05-01-2012 11:52 AM
Tags
12b33, 2011, customer, exhaust, f350, faulty, forf, nitrogen, number, oxide, program, recall, satisfaction, sensor, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
