Adding Cruise Control - Ford Truck Enthusiasts Forums
Old 04-27-2012, 09:24 PM
Intimnasc's Avatar
Intimnasc Intimnasc is offline
Intimnasc is gaining momentum as a positive member of FTE.
I have always wanted to have cruise on this truck but never thought to go to the Junk Yard to get it. Is it difficult to add to a vehicle that does not have it? Besides the steering wheel and throttle linkage what else would I need to get off the donor truck? Is it feasable or a waste of my time?
Old 04-27-2012, 11:01 PM
wolfy's Avatar
wolfy wolfy is offline
wolfy is starting off with a positive reputation.
What are the specs on your truck? year, engine, trans?
I am hoping you have a 91 4.9L custom with the 5 speed. I am just saying, because I would like to do this for my dad's truck.
Old 04-28-2012, 12:57 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Me too!
Mine's the same truck, but a 1992....
Old 04-28-2012, 07:04 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
I've been looking at this also since I have a parts truck with cruise. In the end my decision is to swap cabs due to damage on my project (not just to get cruise, LOL) so I'll have cruise without much other modification.
Here are photos of with/without cruise. As you see, the wiring is already under the hood for the cruise "servo" and the brake pressure switch.
(Note: both of these trucks are 4.9L 5-speeds.)
Of course swapping your steering wheel (or getting another column w/tilt also ...see other projects here) will be necessary. I'd have to do more research to determine if the clockspring would need to be changed or if it's already cruise equipped.
Old 04-28-2012, 08:33 AM
Intimnasc's Avatar
I changed my clock spring a few months ago and the new one has the additional wiring just not terminated. Is there a difference in the PCM or any of that?
Old 04-28-2012, 08:47 AM
ncranchero's Avatar
I don't think so.
Quote:
Fordparts.com shows two clocksprings, one non-cruise and one for with or without. My guess would have been it was cruise ready.
Different animal I know but I added cruise to my 2000 Interceptor with just the steering wheel and cruise servo/amplifier. It was pre-wired for cruise and the connector was just blocked off like this F150. The Vic already had the master cylinder switch though.
Old 04-28-2012, 10:58 AM
BigBlueOx's Avatar
BigBlueOx BigBlueOx is offline
BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.
I put it in my truck (96') with just the wheel and servo. I jumped out the pressure switch with an extra SPOUT plug I had from the parts truck. And the servo/linkage isn't engine specific.
Also if your looking to do the tilt wheel, the clolumn in the 92-96's are already tilt but missing the springs and lever. Plus the plastic with the hole in it for the lever to go through.
You dont need to change the whole column.
Old 04-28-2012, 11:03 AM
From what I'm reading....All that is needed is:
  • Servo that mounts on the fender
  • Cruise style Brake Mastercylinder
  • Thottle cable/linkage
  • Cruis Wiring
  • Steering wheel with Cruise option...
Now, I'm able to grab all that at the local JY I frequent....
But is there anyway that the cruise can be wired into a regular rocker switch?
I have a tilt wheel...Came out of my 1991 Crown Vic...But it's a non cruise model...
Old 04-28-2012, 11:10 AM
ncranchero's Avatar
Quote:
So you just have to disengage it manually........
Also if your looking to do the tilt wheel, the column in the 92-96's are already tilt but missing the springs and lever. Plus the plastic with the hole in it for the lever to go through.
You don't need to change the whole column.
Really? That's good to know.
Old 04-28-2012, 11:29 AM
BigBlueOx's Avatar
Quote:
EDIT
Actually the brake pedal switch is tied into the clutch switch so the one on the master is a redundant saftey.
Yeah. Take a look under there and you will see that it would tilt but it has been pinned in one position. At least that's how it is on all the 92-96's that I've looked at.
Old 04-28-2012, 11:35 AM
BigBlueOx's Avatar
Quote:
Probably. I can post the wiring diagram if you'd like to try it. Lol
Old 04-28-2012, 01:12 PM
That'd be a help, thanks...
Btw, you're correct on the columns...They're all the same..give or take a few pieces...lol
Also, I kinda have my CSS (Clutch Safety Switch) jumpered, because the switch actually failed....
Any issues there, or will it just be in the brake switch?
Old 04-28-2012, 01:36 PM
BigBlueOx's Avatar
The BOO and CSS are wired in series so your only means of deactivation would then be your BOO...not a big deal in my eyes. Lol
Old 04-28-2012, 02:39 PM
BigBlueOx's Avatar
Looks like you may need some rheostats. Lol
and a close up of the wheel.*
Old 04-29-2012, 11:59 AM
Intimnasc's Avatar
Thank you guys going to the JY next week to look and see what it is going to cost me. Thank you for the pics Ranchero I may PM you if I have any issues.
help with cruise control parts highoctane74 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-17-2016 02:54 PM
2000 excursion cruise control issues 550excursion 1999 - 2003 7.3L Power Stroke Diesel 0 12-29-2015 11:43 PM
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 08:42 PM
2000 Ford Excursion Cruise Control Problems? Mitchell_Texas Excursion - King of SUVs 36 08-22-2015 08:14 AM
steering wheel/ cruise upgrade meborder 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-10-2012 07:56 AM
Tags
1992, 1996, add, adding, big, control, cruise, f150, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
