Adding Cruise Control
I have always wanted to have cruise on this truck but never thought to go to the Junk Yard to get it. Is it difficult to add to a vehicle that does not have it? Besides the steering wheel and throttle linkage what else would I need to get off the donor truck? Is it feasable or a waste of my time?
I've been looking at this also since I have a parts truck with cruise. In the end my decision is to swap cabs due to damage on my project (not just to get cruise, LOL) so I'll have cruise without much other modification.
Here are photos of with/without cruise. As you see, the wiring is already under the hood for the cruise "servo" and the brake pressure switch.
(Note: both of these trucks are 4.9L 5-speeds.)
Of course swapping your steering wheel (or getting another column w/tilt also ...see other projects here) will be necessary. I'd have to do more research to determine if the clockspring would need to be changed or if it's already cruise equipped.
I don't think so.
Fordparts.com shows two clocksprings, one non-cruise and one for with or without. My guess would have been it was cruise ready.
Different animal I know but I added cruise to my 2000 Interceptor with just the steering wheel and cruise servo/amplifier. It was pre-wired for cruise and the connector was just blocked off like this F150. The Vic already had the master cylinder switch though.
I put it in my truck (96') with just the wheel and servo. I jumped out the pressure switch with an extra SPOUT plug I had from the parts truck. And the servo/linkage isn't engine specific.
Also if your looking to do the tilt wheel, the clolumn in the 92-96's are already tilt but missing the springs and lever. Plus the plastic with the hole in it for the lever to go through.
You dont need to change the whole column.
From what I'm reading....All that is needed is:
But is there anyway that the cruise can be wired into a regular rocker switch?
I have a tilt wheel...Came out of my 1991 Crown Vic...But it's a non cruise model...
- Servo that mounts on the fender
- Cruise style Brake Mastercylinder
- Thottle cable/linkage
- Cruis Wiring
- Steering wheel with Cruise option...
EDIT
Actually the brake pedal switch is tied into the clutch switch so the one on the master is a redundant saftey.
Yeah. Take a look under there and you will see that it would tilt but it has been pinned in one position. At least that's how it is on all the 92-96's that I've looked at.
That'd be a help, thanks...
Btw, you're correct on the columns...They're all the same..give or take a few pieces...lol
Also, I kinda have my CSS (Clutch Safety Switch) jumpered, because the switch actually failed....
Any issues there, or will it just be in the brake switch?
