Adding Cruise Control - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-16-2013, 04:36 PM
eagle275's Avatar
eagle275 eagle275 is offline
eagle275 is starting off with a positive reputation.
Quote:
Originally Posted by Diesel_Brad View Post
Yeah. I ripped my aftermarket cruise out and threw it in the trash.
I have $74 into my factory cruise set up. I tried it yesterday. Works like a charm.
Alos recalibrated my speedo for the 35" tires too
I had no idea in 2004. Still works like a charm,though.
  #62
Old 05-17-2013, 07:34 AM
Intimnasc's Avatar
Intimnasc Intimnasc is offline
Intimnasc is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Eddiec1564 View Post
May be that's why my cruse control "hunts" while set under 60 mph.....
Is it the vacuum servo or the electronic control that's different?
Yea, I for got to get more fuses the last time at the yard. Got to get a list made for next week.
I was under the imprssion the 92-96 all had electronic servos. I could be wrong but I believe any of those with vacuum were dealer installed and not the factory.
As far as a difference between 5.0 and 5.8 I did not know that Brad. I hope mine still works after changing my 300-6 to a 351.
  #63
Old 05-17-2013, 07:36 AM
Intimnasc's Avatar
Quote:
Originally Posted by samthelion View Post
Question about cruise control
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1> A little background first. I have a 1996 F250 7.3 turbo diesel custom (no frills)
How difficult is the addition of a donor factory cruise control to my ride?
This model has the segregated throttle (electronic control).
Any and all ideas are greatly appreciated.
This I have no idea about all the research I did for this thread and my cruise was for gas motors but I am sure someone here can help you. There are some very sharp individuals on here.
  #64
Old 05-17-2013, 08:56 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> A little background first. I have a 1996 F250 7.3 turbo diesel custom (no frills)
Yours is REALLY simple. All you need is a cruise horn pad. DONE
  #65
Old 05-27-2013, 09:53 PM
samthelion's Avatar
samthelion samthelion is offline
samthelion is starting off with a positive reputation.
Diesel Brad, Thank you for this simplification. I will be trying this and posting the results ASAP.
  #66
Old 05-27-2013, 10:06 PM
eagle275's Avatar
If my aftermarket cruise control goes out, what all do I have to do to install a factory set up?
  #67
Old 05-28-2013, 05:29 AM
Quote:
RIP EVERYTHING that is wired to the aftermarket JUNK out.
Then put in a factory cruise wheel, cruise servo and jumper the Master cyl switch plug. Pretty simple. Alot easier than the aftermarket stuff.
That is assuming you have a 92-96
  #68
Old 05-29-2013, 01:17 AM
eagle275's Avatar
It's a '96 w/C6 and Gear Vendor O/D I installed,Std cab,LB.Thanks!
  #69
Old 05-30-2013, 08:39 PM
samthelion's Avatar
Question
I did the cruise control horn pad but something is still missing. I think I may need the cruise control servo/amplifier assy. Is this thing the same on a diesel as it is on a gas?
  #70
Old 05-30-2013, 08:43 PM
On your truck it is fly by wire. meaning there is no throttle cable. A rheostat in the throttle pedal sends signal to the PCM and that till the injectors how much fuel you are looking for. All the cruise does is tell the PCM to hold what speed it is reading when you set it.
Did you check for any missing /blown fuses /relay?
  #71
Old 05-30-2013, 08:48 PM
samthelion's Avatar
There may be a relay missing. I will check with my Ford guy tomorrow. Thanks for your help.
FOUND IT; I forgot about the SPOUT for the master cylinder.
Cruise now works like a champ.
  #72
Old 10-01-2013, 02:24 PM
MackGuy MackGuy is offline
MackGuy is gaining momentum as a positive member of FTE.
Sorry to add on to an old thread, but this seems to be the most comprehensive add CC thread so far.
What are we lookin at to add CC to a 1990 F250 Diesel Custom? I assume this is vacuum canister, but is it going to be pre-wired?
Also, what does SPOUT mean?
I added CC to my 96 Cherokee a few years ago... Jeep actually sold a retrofit kit that came with the steering wheel control panel, actuator, cable and instructions. Wish Ford had that!
  #73
Old 10-01-2013, 02:59 PM
BigBlueOx's Avatar
BigBlueOx BigBlueOx is offline
BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.
SPOUT (SPark OUTput) connector which on gas models is a small 2 pin jumper that happens to work great for jumping out the brake switch on trucks without it. Ive never added speed control to a diesel so I can't help you there.
  #74
Old 01-01-2014, 04:15 PM
mattfishin8 mattfishin8 is offline
mattfishin8 is starting off with a positive reputation.
It sounds like your in the know on cruise control. I have an 1989 5.8l efi 5 spd 2wd and I would really like to add cruise we have a local u-pull it . Can you help me with this in terms of what to look for on my truck and what I need from the junk yard.
Matt
  #75
Old 01-06-2014, 05:34 PM
Intimnasc's Avatar
Absolutely just find one that some retard hasnt cut the cable on and grab the cruise servo from under the hood right by the master cyclinder. The being as you have a standard there may be a cluth switch you need to grab and a mastercyclinder switch. I just grabbed the master cyclinder switch and plugged it into my wire harness. If my MC ever fails Ill replace it with the one for the switch.
help with cruise control parts highoctane74 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-17-2016 02:54 PM
2000 excursion cruise control issues 550excursion 1999 - 2003 7.3L Power Stroke Diesel 0 12-29-2015 11:43 PM
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 08:42 PM
2000 Ford Excursion Cruise Control Problems? Mitchell_Texas Excursion - King of SUVs 36 08-22-2015 08:14 AM
steering wheel/ cruise upgrade meborder 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-10-2012 07:56 AM
Tags
1992, 1996, add, adding, big, control, cruise, f150, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
