Adding Cruise Control - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-08-2012, 07:05 AM
Intimnasc's Avatar
Intimnasc Intimnasc is offline
Intimnasc is gaining momentum as a positive member of FTE.
You will need the pressure switch off a master cylinder to plug into your wiring. Cruise with automatic has two switches one is already there from the factory the other is the pressure switch in the Maxter cylinder. I would for the short time just take one off a JY truck and plug it into your wiring harness. The other is the brake light switch which all vehicles already come with so you have one already in place. If you have a standard you will ned the clutch switch or be careful leaving that one out since pressing the clutch can and most likely would rev the crp out of your motor.
  #32
Old 06-08-2012, 02:24 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Would a simple toggle switch work?
  #33
Old 06-08-2012, 03:45 PM
BigBlueOx's Avatar
BigBlueOx BigBlueOx is offline
BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.
I used a SPOUT plug to jumper my pressure switch. It works just like it would from the factory. The pressure switch on the master is just a redundant saftey. If its a manual trans then it should already have a clutch safety switch. So as long as you dont jumper that then your safe.
Quote:
Not nessisary.
  #34
Old 08-18-2012, 08:52 PM
tlillard23 tlillard23 is offline
tlillard23 is starting off with a positive reputation.
I have a 1993 F350 xl. I picked up the cruise servo and the horn cover/cruise switches. What does the master cylinder switch plug look like? The picture on page one of this thread does not look like any of the plugs on my truck. I found the obvious cruise plug, it huge...
1st post, thanks!
  #35
Old 08-18-2012, 10:31 PM
Intimnasc's Avatar
Its dark out now but I will take a picture of mine when I get up in the morning. If you took the switch off the donor truck I believe its the only one that will plug into it. I could be wrong so look for a pic or two in the morning.
  #36
Old 08-18-2012, 10:58 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
Has anyone mentioned the year this is coming from/going into? I just skimmed the thread, sorry if I missed it
My 1987 F150 with the FI 4.9L had the same Cruise setup that my 1987 F250 carb'd 460 has.
-Big vacuum actuated servo on the drivers fender with cable to carb/TB
-Vacuum dump switch on brake pedal.
-Vacuum signal going to brain box in dash
-Speedo sensor behind cluster
It is basically a stand alone system. . .just FYI
  #37
Old 08-19-2012, 12:46 AM
BigBlueOx's Avatar
Quote:
1st post, thanks!
Ford calls it "speed control" just for future reference.
If your truck didn't originally come equipped with speed control then your truck most likely will be missing the master cylinder pressure switch.
  #38
Old 08-19-2012, 01:02 AM
I have the servo, the "Connector", etc...
My question is, how do I actually connect the wires in?
Also, I'm looking into a 1997-ish Lincon Towncar Steering wheel....Has all the controls....
  #39
Old 08-19-2012, 02:39 AM
yes, I hear you... it only fits on one connector..... tooo bad I don't have the cruise control master cylinder. I want a picture of the connector, theres 3-4 connectors in the engine compartment. I want to know which one I need to plug/short out. thanks
  #40
Old 08-19-2012, 07:51 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
yes, I hear you... it only fits on one connector..... too bad I don't have the cruise control master cylinder. I want a picture of the connector, there's 3-4 connectors in the engine compartment. I want to know which one I need to plug/short out. thanks
All of that is shown in My POST #4
  #41
Old 08-19-2012, 10:05 AM
I fully understand the part of that connector, but I mean, where do the wires go, to ADD the connector...
Mine doesn't have the OEM connector for CC, nor do I recall seeing that pigtail for the BPS...
UGH......
  #42
Old 08-19-2012, 04:50 PM
ncranchero's Avatar
I can send you a schematic if you think that'll help. Sucks they didn't pre-wire the 92's!
  #43
Old 08-19-2012, 11:45 PM
Quote:
I did go to the junk yard I got the horn pad with cruise control buttons and the cruise control servo. jumpered the brake switch. the cruise works just fine!!
sorry but it's not in your #4 post. If that's were my connector was I would have already had it hooked up ....
I finally found the brake switch and jumpered it. On the 93 f 350 4 door, it's under the truck attached to the frame directly underneath the brake booster. you cant see it from the top of the truck.
thanks for the help your picture did help, I went to the junk yard and looked at 6 or 7 different trucks trying to find that damn connector. it's in a different location on almost every truck
  #44
Old 08-19-2012, 11:52 PM
UGH......
go to the junk yard and look at about 6 or 7 different trucks find 1 with cruise control and see where it comes from and where it goes to. If i had seen this poster earlier I coulda looked at all the trucks for you...
  #45
Old 08-20-2012, 06:11 AM
ncranchero's Avatar
There seems to be two groups of 9th gen trucks, the 92-93 & 94-96. I have 2 94's and a 95 and the photo I posted is common to them.
Maybe you could post up some 92-93 photos of the connectors......
help with cruise control parts highoctane74 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-17-2016 01:54 PM
2000 excursion cruise control issues 550excursion 1999 - 2003 7.3L Power Stroke Diesel 0 12-29-2015 10:43 PM
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 07:42 PM
Dead Cruise control dyoungen 1987 - 1996 F150 & Larger F-Series Trucks 1 12-01-2010 04:34 PM
Pressing Cruise button blows horn!?? vwhed1979 Aerostar 3 01-20-2006 11:24 AM
Tags
1992, 1996, add, adding, big, control, cruise, f150, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
