Oil Cooler Bypass??? - Ford Truck Enthusiasts Forums
Old 04-27-2012, 09:16 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
After reading thru some of the tech. folder. I noticed that the oil cooler has a bypass that is in the oil filter housing and is set at 25 psi... Is it possible that some of the 6.0's over time have weakened say to 20 psi or lower and is allowing hot oil to around the cooler instead of forcing it thru, allowing our deltas to get a larger spread?
It would make sense for all those that have changed oil coolers,done flushes etc, all in trying to reach the under 5* spread.. Is there a way to test the pressure and adjust or replace the bypass?
Any techs that have run into this, and any thoughts on the probability?
Old 04-27-2012, 09:41 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Interesting,
Old 05-09-2013, 01:39 AM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
I have been looking for a part number on this(oil cooler bypass valve). Anybody happen to run across it? Could this potentially be a problem for some?
Old 05-09-2013, 02:33 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Well after all it is a spring and they age and get weak. Maybe when someone does an oil cooler
if the price is not way out there they should just replace the by-pass assembly.
It really depends on cost.
Sean
Old 05-09-2013, 04:27 AM
RPM371's Avatar
RPM371 RPM371 is offline
RPM371 is gaining momentum as a positive member of FTE.RPM371 is gaining momentum as a positive member of FTE.
Great. Something new to worry about.
Old 05-09-2013, 01:38 PM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
If the real problem with the oil coolers is the size of the coolant passages and them plugging due to casting sand/coolant precipitate, then having an oil bypass bypass really wouldn't hurt eot #'s, maybe improve them.
Ideally, having a coolant bypass thru the oil cooler would be the right answer, allowing enough cooler to reach the egr and not allowing heat failures as typical today.
Not sure there's room, nor that would solve the problem?
Old 05-09-2013, 04:48 PM
Yahiko's Avatar
I think that they would have to really rework a few things.
That being said it could be done. If it were done then a PID for
by-pass should be added because you won't get any oil cooling
and it will get hot fast and cause other problems.
Out of the frying pan and into the fire! Type problems.
Sean
Old 05-09-2013, 04:54 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I'm wondering if you're refering to the oil filter bypass that's part of the standpipe that will allow for filter bypass if the filter clogs??
Old 05-09-2013, 08:42 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Page 22: Lubrication System
Page 25: Lubrication System
Josh
Old 05-10-2013, 01:12 AM
jswartz84's Avatar
It looks like it is held in by the two torx screws that locks the standpipe in place. Its brass with a spring. I guess I am wondering if when it is open it bypasses the oil cooler? Is it possible for it to be open all the time and not sending all the oil through the cooler?
Old 05-10-2013, 01:17 AM
jswartz84's Avatar
Josh,
Thanks, I must have missed page 22. I assumed the filter was pre cooler.
Old 05-10-2013, 06:51 AM
Quote:
Originally Posted by Bullitt390 View Post
Ahhh yes. I had forgotten that little feature (can't get those pic's at work sometimes). I've seen more than one of those that have grooves worn into them and IIRC it is a replaceable part but don't know that clogging of the oil side of the cooler has ever been a problem and I THINK that is a differential pressure bypass.
Old 05-10-2013, 10:09 AM
jswartz84's Avatar
I figured it was serviceable but can't seem to find a part number. I'm not really worried about a plugged oil cooler, i just wonder if this spring gets weak or no longer functions and let's oil bypass the cooler all the time. Because of the size, I wonder if it would even matter if it was bypassing
4R100 Bypass Tube Kit, need some input / advise 2003F-350SuperDty5.4 1999 to 2016 Super Duty 66 12-07-2016 08:50 AM
High EOT's AFTER repairs. 06FUN 6.0L Power Stroke Diesel 115 10-29-2016 08:53 AM
BPD Style Oil Cooler Remote Mount Kit billbot 6.0L Power Stroke Diesel 49 12-27-2015 11:51 PM
Just wanted to say thanks to everyone CountryMonkey07 6.0L Power Stroke Diesel 4 03-27-2015 10:52 PM
oil cooler and bypass filter NavyMIDN08 1994.5 - 1997 7.3L Power Stroke Diesel 1 03-07-2010 04:51 PM
Tags
460, 60, 64l, 75, 96, bypass, cooler, duty, f350, ford, oil, power, steering, super, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
