Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-27-2012, 07:33 PM
jeff gammon's Avatar
jeff gammon jeff gammon is offline
Garage is empty, add now
jeff gammon is starting off with a positive reputation.
Autolite 2100
I have one on a 390 in a 67 model. How hard is it to rebuild one fro someone that knows nothing about carbs? Mine has gas coming out of 2 of the 4 hollow post that stick up on top of it. I am assuming it is some type of float problem. Any help would be great. Dont really want to buy a new carb. but might have to.
Thaks,'
Jeff
  #2 (permalink)
Old 04-28-2012, 01:01 AM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.
google "rebuilding Autolite 2100 carb"
the first three pages are pictoral instructions on how to do it.... it's stupidly simple.
$14 is about average for a rebuild kit.
If you don't want to rebuild it, it just sounds like you need a new float or needle valve.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
  #3 (permalink)
Old 04-29-2012, 01:49 PM
KO1960 KO1960 is online now
1965 Ford F-250
KO1960 is starting off with a positive reputation.
The rebuild kit has instructions as well. Be prepared to spend two days for the process. One day will be tear down and soaking carb body in cleaner. The next will be blowing out all passages and reassembly. Make certain that the float actually floats. A float does not come with the kits. Good luck.
Kurt
__________________
Plumber by trade-mechanic by weekend
1965 F250 Camper Special w/ 390
  #4 (permalink)
Old 04-29-2012, 02:43 PM
huh. float came with the kits I was getting.
Also the manual will show (and you will also receive) a bunch of parts that you do not use. So be advised.
__________________
-76 F100 390FE
  #5 (permalink)
Old 04-29-2012, 06:34 PM
1965 Ford F-250
A float didn't come with mine; although, the parts man asked me if I needed a float. Maybe I'm cheap. You are right about the extra parts. It's a good idea to have the carb tag number handy - if one exists.
__________________
  #6 (permalink)
Old 04-29-2012, 06:45 PM
arctic y block's Avatar
arctic y block arctic y block is online now
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
Like the Man said. Each kit comes with instructions. So do Automatic transmission kits. If ya have ever built an AMT Model Car from a kit ya can do this. Just make sure ya got a super clean place to work and super clean everything. Also know that the carb cleaner ya soak the parts in will eat everything that aint metal.
And in your case get the kit with the float with it.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #7 (permalink)
Old 04-29-2012, 07:49 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
It ain't what it used to be. Used to make the metal look new. Love the tree huggers.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #8 (permalink)
Old 04-29-2012, 10:12 PM
1972-34ton 1972-34ton is offline
1972 Ford F-250
1972-34ton is starting off with a positive reputation.
Follow the directions on the carb cleaner. Overnight is not necessary, and you may cause problems that way. As an example, more than an hour in fresh carb dip will damage the MC 2100-2, and 2100-3 carbs. They have some teflon seals that are ruined this way. Brass and plastic parts don't go in the dip.
Try to blow out the passages from the inside of the barrels out, and from the bottom of the carb, up. Ordinary carburetor spray is handy for checking to see if the passages are open (same pattern of blowing, where possible). Don't drive the dirt down into places that get smaller and smaller!
Follow the directions with the carb rebuild kit exactly. Don't try to dissassemble things more than required. Don't remove the shafts. Watch U*Tube videos, they help. Don't use silicone seal (RTV)... It isn't hard to do correctly, but guys sometimes do things not required, and cause extra issues.
If you really have trouble, PM us for anything that isn't clear. Setting the choke linkage and figuring out which instruction steps apply to your particular carb may be a little confusing the first go-around.
Did I say Follow the directions with the carb rebuild kit exactly?
__________________
I said, "the nut went down the intake manifold!"
...That's when the pain started...
Tags
1968, 1972, 2100, autolite, carburetor, decoder, designation, ford, instructions, mustang, rebuilding, shocks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
