Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.7L Power Stroke Diesel 2011-2012 Ford Powerstroke 6.7 L turbo diesel engine SPONSORED BY:
  #1 (permalink)
Old 04-27-2012, 07:05 PM
Barrie guy Barrie guy is offline
Garage is empty, add now
Barrie guy is starting off with a positive reputation.
DRW Valve stem extensions ?
Anybody have advice on valve stem extensions for a F350? I am having trouble checking tire pressure which I like to do often.
  #2 (permalink)
Old 04-28-2012, 05:23 PM
JohnD333 JohnD333 is offline
JohnD333 is starting off with a positive reputation.
Campingworld.com
Search "valve stem"
Easy soft rivet to plastic/chrome hub cap. For 16 to 19.5 tires
  #3 (permalink)
Old 04-28-2012, 11:47 PM
porthole's Avatar
porthole porthole is offline
porthole is gaining momentum as a positive member of FTE.
Before adding a TPMS I used 6" stainless braided extensions. Also used a piece of clear tubing which was held on by a stainless washer under the valve stem cap.
No brackets to hold stem, just laid against the wheel opening.
__________________
Thanks, Duane
2011 Tri-coat F-350 DRW
  #4 (permalink)
Old 04-29-2012, 12:06 PM
Fulltimer50's Avatar
Fulltimer50 Fulltimer50 is offline
Fulltimer50 is starting off with a positive reputation.
Click the image to open in full size.
I use a gauge that has a tip like this one and have no trouble checking or adding air pressure.
__________________
George
6/2011 F350 6.7PSD 4X4 CC LB DRW Lariate
2013 Lifestyle LS37RESL 5th Wheel
  #5 (permalink)
Old 05-01-2012, 12:33 AM
Thanks guys I appreaciate that
Tags
drw, extenders, extension, f250, ford, stem, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
