Dana 60 swap with rsk and Death wobble now!
So about a month ago I swaped in a 97 dana 60 from a psd and Rsk kit. I put a stock steering stabiler on. Had it alined and drove it around. Drove fine for a few weeks. Then I started getting a bad death wobble. It would come and go. Would shake the truck so bad u cant drive it. So I started looking around for a cuase. I found the driver side had 2 bad ball joints. I had them replaced with moog ball joints and u joints why I was at it. All 4. I got the truck back today and found it still has the death wobble. I called the place that alined it and they are going to redo it cause it still in warrenty.
To check the TRE's I had my little brother shake the wheel with out the truck running. There was no play in any of them. What I did notice was that the tie rod bar was rolling back and forth. I have never seen this before and was woundering if it normal. Also any ideas where else to look for a problem. I was suppose to be on my way to a psd gtg tomorrow but sadly I'm not going anywhere. I was gonna check all my bolts in the front end and rsk.
It happen when getting up to around 20 to 40 mph. Also if u hit a bump in the road the right way or hit a pot hole. Some bumps do nothing other set it off. Today I was getting up to a 35mph zone and it happened. Newly paved road. Then I hit the brakes back down to about 10mph and it goes way. I dont under stand what i'm missing but it got me pissed!
Thanks Doug
Thanks Doug
theclintonsx4
12-21-2011 12:05 PM
