Track Bar or Not??
Received 3,102 Likes
on
I'm serious, ONLY death wobble, I have ever had was all because of the tires. If everything is in good order, wobble should not happen.
A steering stabalizer will lessen the wobble, but that's really just a bandaid. No reason for any wobble if the tie rods, ball joints, alignment, and bushings are in good order, unless the tires are to blame.
on
i have to agree with Dave on this one. the only trucks i ever owned that experienced death wobble were the ones with front shackle springs.
my 66 W-300 power wagon, the 2 jeeps, the 78 F-250, the 3 79 F-350's the 2000 F-350, the 2002 F-250 never have any problems. the trick is rear shackles.
NEW tires and wheels balanced and only needed 1oz or less
New ball joints
New tie rods.
New drag link.
New sway bar bushings
New wheel bearings.
New shocks.
New springs
Alignment.
I cant think of anything else that would be "amiss"
New ball joints
New tie rods.
New drag link.
New wheel bearings.
New shocks.
New springs
Alignment.
Do you "need" one no maybe not however if it where me I'd run one rather then go without even if didn't seem to have a "problem".
May not suffer deathwobble now but say after few hundred miles alls been well, parts suffered little wear here and there over time. Nothing big worn out no just a little at each point but combine its enough.
Everythings has been rock solid, your driving without a care in the world, so you hit 45 50ish MPH say, then you hit a dip or bad grove in the road surface. Suddenly all heck breaks loose and you have very little control shes breaking up, pressure line to PS pump blows fluid all over hot exhaust smokes flying from under hood, you just went into that dreaded deathwobble. Wouldn't you know it this time your wife/kids they are riding with you (they'll never get back in it again regardless what you claim you "fixed").
(Little melodramatic? yea perhaps but you get the idea!)
Worth it to not have that bar in place? not to me it wouldn't be.
Get definite/solid axle positioning with one, centered at all times something the leaf springs can only do but is limited, a task they're just not intended to handle.
Oh and you will suffer bumpsteer, if you don't install it right.
