Aussie 302 heads - Ford Truck Enthusiasts Forums
Aussie 302 heads
Old 04-27-2012, 01:54 AM
thatsrealnice's Avatar
thatsrealnice thatsrealnice is offline
thatsrealnice is starting off with a positive reputation.
Aussie 302 heads
Hey guys, So I have a chance to buy some Aussie 302 heads from a local guy. He's asking $400 for them, one of them was taken apart in anticipation of rebuilding them to use on a Mustang which he's since sold, and still has the heads. Is $400 a good price, and is there anything in particular I should be looking for before buying them? Won't be able to use them for quite a while anyway until I can save enough money to rebuild my 400, but I've been reading a lot how the Aussie heads will help boost the compression ratio, and have looked online, and the ones that have been all gone through are quite expensive. Let me know your thoughts, thanks.
Old 04-27-2012, 09:40 AM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
I bought 2 sets and both sets were not useable. Id ask him if you could take them to a machine shop and get them checked over.
Old 04-27-2012, 09:57 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
We are talking about a set of 335 series heads ? For what you would probably have to put into them and what a new set of aluminum heads go for there is no way I'd consider them.
Old 04-27-2012, 11:59 AM
This is to build up my 400 engine. I've heard the Aussie heads are much better than American counterparts because they are 2 valve but have closed chamber like the American 4 valve chambers. Are there aftermarket aluminum heads that will fit a 400?
Old 04-27-2012, 03:46 PM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Any aftermarket 351C head should fit a 400.
Old 04-27-2012, 05:11 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Edelbrock and at least one other company make the aluminum heads. Check TMeyer or Summit. They are pretty spendy.
For a pickup, I personally would prefer the iron heads. That's the route I'll likley take if I get into my 400. The Aussi heads, like aluminum, make it possible to build an efficient quench engine with streetable compression. TMeyer can supply the special piston needed to make it work.
If the heads are in decent shape and just need basic freshening $400 is a good deal. If they need a lot of work, not so good.
Do you know why the PO changed his plans and didn't use them?
Old 04-27-2012, 07:22 PM
Quote:
i got CHI 2v heads on my 400 from Kaase. check them out. besides using pistons that take advantage of the quench area, they don't require much work to use.
Old 04-27-2012, 07:55 PM
hillbillyk hillbillyk is offline
hillbillyk is starting off with a positive reputation.
I bought a set years ago from a guy that imported them, went through a bunch of cracked ones to find a good set, when I was done I had 1k in rebuilding them but they did make for one heck of an engine that made alot of power.
Old 04-28-2012, 01:23 PM
He was going to build up a Mustang with them, but he sold the car so he's had them lying around for years.
Old 04-28-2012, 01:28 PM
Quote:
You have a link for them?
Never mind, I found them. Not cheap. I'm really just wanting to improve compression and highway rpms. Not looking to race it or anything like that.
Here's the link for the CL ad. http://denver.craigslist.org/pts/2970954336.html
Old 03-03-2014, 05:39 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Did you ever get your Aussie 302 heads running? I just bought a pair and want to put them in my 351C. But am concerned about possible problems that may arise.
351c build 77custom408 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 11-14-2016 11:17 AM
400 with Aussie heads dimora 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 22 05-30-2016 09:41 PM
2v aussie head valve covers breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-30-2014 05:33 PM
400m headers....what should i use? 77 f-250 highboy breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-11-2014 07:51 PM
2v aussie heads breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-28-2014 06:47 AM
Tags
2v, 302, 302c, 400, 400m, 4x4, aluminum, aussie, australian, craigs, ford, heads, list, racing, specs, summit, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
