In-cab sound deadener.
I spent a fortune on Noisekiller in my previous truck with great success. (You have no idea how much wind noise the 61-66 cab produces until you mask all other noise.) Anyway, I know some of the cheaper stick-on products are "asphaltic" in nature, so I thought I'd try "torch-on" roofing material, which is asphaltic and, best of all, absolutely free in smallish pieces to those of us who work in heavy construction.
Any thoughts?
Eric
Any thoughts?
Eric
I've got a product called Pittwrap which looks similar to the Dynomat. It was given to me by an insulator. It is intended as a piping wrap, but the insulator told me that it works well in his, cough, chevy. I wouldn't know since I haven't installed it yet, but it was free. Good luck Eric.
Kurt
Kurt
Purchased a product that states it duplicates OEM sound deadening panels that meets OEM specks. The product is manufactured by Evercoat, they are self adhering 12x12 sheets of what appears to be an asphalt base type material, look like 12x12 sheets of rolled out tar. Installed them inside doors on the 65 where they fine until the cold winter months set in and they started peeling off. Took hair drying in an attempt to reinstall with no success!! I would not recommend them if live in cold climate.
Good stuff!
Very popular here in Florida - Quick Roof™ instant waterproof repair for regular and rubber roofs
Original QUICK ROOF ™ Self-Stick Aluminum Roll Roofing
Available at H Depot
I tell you guys do some research on Lizard Skin, I have seen this stuff and it is amazing. The sound deadener is like the quiet cab Ford uses on the New F150's and the Heat dissipater is nothing short of a miracle. I know of a guy who has an Electric Skillet and half of it is painted with Lizard skin Heat dissipater. He cooks an egg on the unpainted side while he puts his hand on the Lizard Skin. Now don't get me wrong he can't leave it there, put you can put it there for a couple seconds without a burn. I am going to spend about $300, and Sound Deaden, and Heat Dissipater from the firewall to the back window, on the bottom, and the Windshield to the back window on the top. I should also have enough to strip the doors of all the hardware, and then do the inside of them as well.
F-250 restorer
34
01-02-2019 08:42 AM
