FICM Poll - Page 2 - Ford Truck Enthusiasts Forums
FICM Poll
Old 04-30-2012, 04:36 PM
FICMrepair.com FICMrepair.com is online now
SPONSOR
FICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to behold
/agreed! Nothing to worry about there!!
Old 04-30-2012, 04:38 PM
archtaan's Avatar
archtaan archtaan is offline
archtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputation
Good to know. I watch it every day. Once it starts to hold a low voltage i will be sending it in for updrade. Thanks!
Old 04-30-2012, 06:02 PM
scottf4444's Avatar
scottf4444 scottf4444 is offline
scottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant futurescottf4444 has a brilliant future
I replaced mine at 105k miles with the Innovative 48V. I could tell a difference in it running better. I still like it 30k miles later.
Old 04-30-2012, 06:03 PM
archtaan's Avatar
What kind of changes did you experience?
Old 04-30-2012, 09:17 PM
Peace2Peep's Avatar
Peace2Peep Peace2Peep is offline
Peace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to behold
How do you know what voltage it is holding? How do you test it?
Old 04-30-2012, 09:25 PM
archtaan's Avatar
It is one of the pips I monitor with the Edge CTS monitor. I know the dealer can check it, plus there is a field way to test it, but I don't know the details.
Old 04-30-2012, 09:30 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Quote:
A voltmeter works in the driveway, but is the hardest method to perform testing.
A Scanguage II or similar is the easiest. With a 6.0, you really should have something to keep an eye on a lot of things.
The Torque app with a Bluetooth OBDII adaptor also works great.
Old 04-30-2012, 11:26 PM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
I had never had a problem with mine... Till i hooked up my CTS, found my FICM voltage was running low and would get up to voltage as it warmed up. Tried to repair it myself, and ended up breaking a few caps and resistors splitting the case. Luckily, I found a guy local to me that had newly rebuilt units for less than 200.00 w/ a core swap.
Old 05-01-2012, 07:30 PM
scottf4444's Avatar
Quote:
Throttle response is better and then there's the standard nondescript "It just runs better"...especially when it's cold out. It supposedly gets better fuel mileage but my driving styles vary so I could never get a true reading.
Old 05-02-2012, 12:38 AM
SPONSOR
Many FICM's fail so gradually that by the time you get a new one, you are left with this feeling like 'so THIS is how my truck is supposed to run...'.
__________________
Ed
Ed@ficmrepair.com
2005 Excursion 6.0 PSD. RAS, 4" MBRP T409, Edge Insight CTS, ScanGauge II, coolant filter, DELO ELC, upgraded FICM from FICMrepair.com, SCT, blue spring upgrade, trans bypass filter, Rancho 9000XL's, SS ESOF lines, Rotella 5W40, Clifford Remote Start, Prodigy.
How to Fix Your FICM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! DrQuad 6.0L Power Stroke Diesel 182 11-28-2016 05:16 PM
FICM firedaniel 6.0L Power Stroke Diesel 60 01-21-2014 01:56 PM
FICM repair and upgrades thread! the_auto_tech 6.0L Power Stroke Diesel 14 02-16-2013 09:19 AM
Failing Injectors Cause Low FICM Voltage? 1957F100 6.0L Power Stroke Diesel 2 02-09-2013 07:38 AM
SGII users & FICM Specialists amdriven2liv 6.0L Power Stroke Diesel 25 09-08-2011 02:34 PM
Tags
04, 05ford, 06, 60, auto, diesel, fcim, ficm, ficms, flucuations, glacier, northern, parts, powerstroke, psd, threw, tunes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
