A very strage no start
Old 04-22-2012, 11:05 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
Well my truck left me stranded at a park today. Hop in, key goes in the ignition, truck powers up but will not start. Run to auto zone and get a new lock cylinder and same problem, key turns all the way but no start, also truck will no longer power down, even with the key cylinder removed the truck stays on.
I will be disconnecting the chip in the AM however after that I am stumped
Any recommendations?
Old 04-23-2012, 06:10 AM
landmobile's Avatar
landmobile
landmobile is offline
Sure sounds like a bad ignition switch, or perhaps a problem in the mechanical linkage between the lock cylinder and switch.
Old 04-23-2012, 08:17 AM
Waltdog's Avatar
Waltdog
Waltdog is offline
It's definitely the mechanism after the ignition cylinder as a new replacement cylinder functions the same as the original. The strange part is the truck cannot be turned off ( engine not running ) I had to disconnect the batteries . The dash powers up as normal but can't remember if I got a WTS light
Old 04-23-2012, 08:18 AM
bigb56's Avatar
bigb56
bigb56 is offline
I agree you should check the switch, not the cylinder.
Old 04-23-2012, 02:13 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
What switch should I be checking?
The dash powers up and all of the lights work however the starting is not turning over No click or anything
Old 04-23-2012, 02:19 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Subcribing to this one.
Chet
Old 04-23-2012, 03:30 PM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
There should be a switch on the steering column Walt. Double check there.
Old 04-23-2012, 07:37 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
Ok just came in from working on truck, it continues to not crank. More info:
Chip has been removed
Tach sweeps and WTS light is coming on
No codes
OD light turns on if I push the button
As soon as the batteries are hooked up the dash/lights turn on even with the ignition cylinder removed
Wheres the switch on column and what am I checking for there??
Old 04-23-2012, 07:56 PM
landmobile's Avatar
landmobile
The switch is on the passenger side of the steering column. Here is the wiring diagram (from a 1999 manual):
Chris
Old 04-23-2012, 11:00 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Old 04-23-2012, 11:02 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I don't know if the ford mounts are kinda the same as Chevy switches on the steering column. But on the chevys. the switch has a slotted holes to adjust the electric switch position. if the screws come lose on the electric switch, it will move up the column and the rod from the key-switch will not pull or push the electrical switch to the right position
Old 04-23-2012, 11:03 PM
sand_fiend's Avatar
sand_fiend
Originally Posted by PaysonPSD
Link No Work..
Old 04-24-2012, 09:19 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by sand_fiend
Link No Work..
Works for me. Do you have Adobe PDF reader?
Old 04-24-2012, 11:08 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
I tried it also Robin and it wont work and I have PDF reader.
Old 04-24-2012, 11:26 AM
PaysonPSD's Avatar
PaysonPSD
Here's a new attachment. Let me know if it works.
File Type: pdf
Quick Reply: A very strage no start
