Fuel Selector Switch wiring - Ford Truck Enthusiasts Forums
Old 04-26-2012, 04:30 PM
jdsunset jdsunset is offline
jdsunset is starting off with a positive reputation.
I have recently bought a 72 F250 Camper Special with a 360. Neither of the fuel tanks are registering. The previous owner tried to install a different switch and cut all the wires. I have the correct switch and need to find out the correct way to wire it up. any help would be great. Thanks
Old 04-27-2012, 02:25 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Welcome to the forums.
I don't have the wiring diagram, but likely a DPST(double pole, single throw) switch is used.
I also don't know what the switch looks like physically, but electrically speaking:
The "common" post of the switch goes to the dash(guage), the other two posts accept the wires from each tank sending unit. Thus the two positions of the switch gives you readings from alternate tanks.
Hope this help some.
Old 04-28-2012, 07:32 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1967/72: With the factory installed auxillary tank, there is a manually operated fuel tank selector valve on the floor adjacent to the drivers side of the seat.
Below the dash, to the left of the steering column, mounted on a bracket is the fuel tank switch (D3TZ-9A050-B replaced C1TZ-9A050-A) that only switches the dash fuel gauge from one tank to the other.
Behind this switch is a bezel (C1TF-10852-A) that is marked: L. FUEL TANK R.
1970/72 factory installed auxillary tank: The exposed fuel cap pokes thru the quarter panel (bedside) below the scallop (bumpside) line in front of the left rear wheel.
If the fuel cap is mounted in the bed, or behind an aluminum door that is riveted to the quarter panel, it is not a genuine Ford auxillary tank, the switch isn't genuine Ford either.
2 speed wiper switch wiring C.P. 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-24-2014 07:54 PM
Wiring ID at Connector to Neutral Safety Switch 80s Trucker Electrical Systems/Wiring 3 08-21-2014 08:29 AM
1986 F150 neutral safety switch wiring diagram DGMFORD 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-17-2013 11:42 PM
Problems switching fuel tanks cbowman85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-10-2007 09:03 PM
light switch wiring CaptCrunch 1961 - 1966 F-100 & Larger F-Series Trucks 4 10-23-2006 09:17 PM
Tags
1979, 69l, ac, air, check, diesel, duty, f250, ford, fuel, selector, super, switch, tank, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
