Oil Cooler change, wont start - Ford Truck Enthusiasts Forums
Old 04-26-2012, 01:22 PM
little rog little rog is offline
little rog is starting off with a positive reputation.
I just completed an egr delete, oil cooler replacement on my 06 6.0 diesel
I believe I did everything correctly and everything went back together fine, I just cant seem to get it to fire. i am getting fuel cause i noticed it squirting out of the top filter cap hole, so i replaced the o ring there, cycled key on and off several times to try to purge air.
is there anything i could have done when filling with oil to help with the circulation of oil and pressure build up? i think i got a little too proud of myself too soon thanks for any info you may have Roger
Old 04-26-2012, 01:25 PM
mblanken881 mblanken881 is offline
mblanken881 is starting off with a positive reputation.
You have to crank for a long time. I didn't think mine was going to fire either but it eventually did.
Old 04-26-2012, 06:09 PM
Thank You for getting back to me, i have been trying for last hour to start and have had no luck. My batteries are not the newest, so i only get a couple trys at about 10 seconds a try. Am i building up oil pressure then loosing it when i have to take a break? I may just go get 2 new batteries and install, whats another 120.00. i checked to make sure the ground wire at rear drivers manifold was connected, it was placed on the stud then run down. touching alum and the nut. good idea? not sure what else i could have missed
Old 04-26-2012, 08:12 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
You're going to need GOOD batteries. Don't fry the starter.
Old 04-26-2012, 08:32 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Did you fill the HPO reservoir or oil cooler any during reassembly????
If not its going to take alittle longer
Give it a Few 30 second cranks rest a minute or two inbetween and check the Oil leval its gona go down as it fills back up and then hit it again
You wont burn the starter up like that
its the folks that Panic and crank and crank 2-3minutes over and over that kill the sstarter
now if you crank for upto3-4 minutes TOTAL CRANK TIME or more with out it starting you might have an issue
I dont think you have cranked it long enough at all keep going keeep the charger on them Batterys and dont worrey them starters are TOUGH give her Hell LOL
BPD Style Oil Cooler Remote Mount Kit billbot 6.0L Power Stroke Diesel 49 12-27-2015 11:51 PM
Headgaskets after oil cooler replacement? Magnolia Tom 6.0L Power Stroke Diesel 4 04-18-2014 11:44 AM
Oil Cooler Replacement Russell N. 6.0L Power Stroke Diesel 15 02-20-2014 01:14 AM
Whats a good aftermarket Oil Cooler? DawnPatrol 6.0L Power Stroke Diesel 5 03-07-2013 09:47 PM
Oil Cooler R&R Help tttario 6.0L Power Stroke Diesel 16 11-26-2009 06:19 PM
Tags
05, 60, 73, change, changed, changing, cooler, diesel, f350, oil, pressure, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
