Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-25-2012, 11:54 PM
Matthew Christiani Matthew Christiani is offline
Garage is empty, add now
Matthew Christiani is starting off with a positive reputation.
85 2.3 Wont start
After a head gasket change it simply will not start. I thought it was the ICM but we tested it and its not. I have all the new sensors and air control valve dealies and what not.
I have spark and fuel. How much fuel, i don't know. I have roughly 33lbs of fuel pressure at the rail.
I noticed an elbowed vacuum port that runs underneath the throttle body but it has no hose attached and i dont know where it goes, where it comes from, or what it does. And i don't remember taking it off. We thought maybe THAT lack of vacuum pressure is messing with the Mass Airflow Sensor or something and causing it not to pressurize the fuel system start but i cant find a picture, diagram, or see any place that hose comes from.
another weird thing is that i can spray either into the the throttle body and even that wont start it... im completely out of ideas. what do yall think? Another thing i think it might be is the computer might have gotten moist when i left the truck window down one night. it didnt rain hard, and i doubt it but maybe?
  #2 (permalink)
Old 04-26-2012, 06:28 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Timing belt correctly installed?
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 04-27-2012, 10:13 AM
We took the belt of several times because we thought well, just maybe were firing on the exhaust stroke or something. But we werent, and now the timing is like 1 maybe two teeth off. but it should still start, and when it was timed perfect it didnt start anyway.
right now im looking for a vacuum diagram for hoses that go to the throttle body cuz i think im missing one that tells a sensor what to do.
Last edited by Matthew Christiani; 04-27-2012 at 10:15 AM. Reason: additional info
  #4 (permalink)
Old 04-27-2012, 10:37 PM
critterf1's Avatar
1 or 2 teeth off with fouled plugs will not start.
__________________
Tags
23, big, body, carburetor, ford, start, throttle, v8wont, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
