Old 11-25-2014, 02:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
2wd to 4wd Conversion
Old 04-25-2012, 09:50 PM
Kaizer88's Avatar
Kaizer88
Kaizer88 is offline
Hey guy I need some advice on this conversion... Can I use my 2wd AOD tranny and put a transfer case on it? What would be the best axle ( i want to do a straight axle) and transfer case. Ive read on other sites that its a straight swap bolt on and very long procedure. Please dont tell me that it would be cheaper to buy a 4x4. Becasue I love my truck. I want to do a manual shift on the 4x4 and manual lockouts. I would like to use a 70's axle (dana 44???) and np205 t-case.
Old 04-25-2012, 10:03 PM
95f2504x4's Avatar
95f2504x4
95f2504x4 is offline
From 87 to 96 all the frames were the same, including 2wd and 4wd frames. Basically to save money Ford built all the trucks on the exact same frame so that is a plus. Unfortunately the 2wd aod will not work and you will have to find a 4wd version. As far as the front axle the 78-79 Ford f150s will have the solid axle dana 44 which is what you want. Just make sure to get one with disc brakes.
Old 04-25-2012, 10:10 PM
Kaizer88's Avatar
Kaizer88
Kaizer88 is offline
i cant swap out the tail shaft and put the t case on it?>
Old 04-25-2012, 10:16 PM
95f2504x4's Avatar
95f2504x4
Not quite sure on that one. Both times I have done it we swapped out that autos that were in it for manuals anyways. Someone who has a little more experience with the autos will chime in soon though.
Old 04-25-2012, 10:21 PM
95f2504x4's Avatar
95f2504x4
If the swap does work though if your going to swap out the tail shaft it means you will prob have to get a tail shaft from a 4wd so why not just use the whole trans you get for just the tail shaft?
Old 04-26-2012, 03:49 AM
fdude64's Avatar
fdude64
fdude64 is offline
the frames between 4x4 and 4x2 are not the same as you can see in my build thread. there are quite a few differences.
Old 04-26-2012, 09:29 AM
95f2504x4's Avatar
95f2504x4
What are the differences then cause my 95 and 92 both have the same frame on them.
Old 04-26-2012, 09:51 AM
sticky58's Avatar
sticky58
sticky58 is offline
the tailstalk conversion will only work with a standard tranny,the output shaft is different in 2 wheel. the rear springs are bigger along with the hangers on a 4x4.driveshafts will vary among diferant styles,my short box stepside 4x4 was made for under $200. If you stick with the same model year, the front end will bolt right in.Spring and shock towers, radias arm brakets are the same. You should stick with same tranny style or go standard as your computer will like this also.I have done 4 coversions and all have done well,Its a real good time to rebuild all of these componets while they are out of the truck.
Old 04-26-2012, 11:29 AM
fdude64's Avatar
fdude64
fdude64 is offline
well for one thr front of a 4x2 is open where the 4x4 is boxed to mount the leaf spring shackle, the transmission crossmembers are totaly different so the front driveshaft can pass it.
Old 04-26-2012, 11:52 AM
sticky58's Avatar
sticky58
sticky58 is offline
your right the crossmember is different from 2 wheel to 4 and possibly std to auto.The frame changed in 92,bumber brackets etc changed in 92,because yours is older than 92, you`ll wanna stick with that generation as 92 and up are electonic. this can all be accomplished, if you stick within the same generation, it will make it easier to convert..
Old 04-26-2012, 12:03 PM
fdude64's Avatar
fdude64
fdude64 is offline
yea my frame is a 91 f350 4x2 and everything else is 95 f350 4x4
Old 04-26-2012, 12:12 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Half tons, the frames are the same up front. Because, isn't the OP talking about a 89. F-150? So, a TTB is a bolt in swap, a SAS, is part bolt in.
Anyways, in a manual or auto, you can swap out the tail shaft, along with the tail housing to make it a 4x4 trans. But that requires total disassembally.
A SAS is a easy task for a good backyard mechanic. If you have everything ready it can be done in a weekend
Old 04-26-2012, 12:20 PM
fdude64's Avatar
fdude64
fdude64 is offline
ok my bad didnt see the f150 part, all i have had was f250 and f350 and have found many differences between 4x2 and 4x4
Old 04-26-2012, 07:54 PM
95f2504x4's Avatar
95f2504x4
Ya the f150 was what i was referring to. I looked at my f250 and f150 and in both of the same section in front of the engine crossmember are both boxed. Behind the engine crossmembers are both open.
Old 04-27-2012, 08:37 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
IIRC also the rear 4x2 springs are 2.5" and the 4x4 rear springs are 3".
Quick Reply: 2wd to 4wd Conversion
