2005 F250 Super Duty 5r110w Problem - Ford Truck Enthusiasts Forums
Old 04-25-2012, 09:31 PM
gilllawn gilllawn is offline
gilllawn is new and has a neutral reputation at this point.
I have an 05 F 250 super duty with the Triton in it. When I shift either into overdrive or reverse the transmission hesitates (does not go into either gear for about 5 to 10 seconds). After that it engages and it's fine. It does not appear to be slipping or acting up regardless of temperature or speed. Sometimes it will sort of engage and than bang into gear solid. I do not have any check engine lights. Not sure if the PCM has any codes. So I'm trying to figure out if I need to have a complete rebuild or if I have a valve / solenoid body problem. Any help would be appreciated. Where do I start?
Old 04-25-2012, 09:44 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
Fluid level?
Old 04-25-2012, 09:56 PM
Fluid Level
Fluid level is right on the money. I actually dropped the pan but didn't find any metal schillings or anything abnormal. Change the filter and pan gasket and added about 9 quarts back in. In addition, I put some Trans X in it just to see if that would clear up a possible sticking solenoid however it did not make a difference.
Old 04-30-2012, 11:13 AM
fordfarmer12 fordfarmer12 is offline
fordfarmer12 is starting off with a positive reputation.
Quote:
I have the same problem with my 05 Triton as well. It normally doesnt last quite that long, maybe 3 or 4 seconds, but definatley longer than it should take. Ive never changed the fliud and I have 118,000 on on the truck so I'm wondering if the fluid just needs changed, its starting to get a little thick but not too bad, or if its another issue.
P.S. How hard is it to change the ATF?
Old 04-30-2012, 03:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The 5R110 is VERY sensitive to fluid. If the fluid gets old or has particles in it the solenoids will get contaminated and stick. Then you can get all sorts of issues, including 5-10 second engagements.
Change the fluid and it might get better. If there is enough contamination in the solenoids the only fix is to replace the solenoids.
It isn't hard to change the fluid, as long as you have a heated flush machine handy. If you don't, it's really hard. There is an internal thermostat that will get in your way if the trans is cooler than 170F.
Starter engages after truck is running Topprop2 1999 to 2016 Super Duty 1 12-23-2016 05:03 AM
5R110 TorqShift Problem and Questions Mark W. Ingalls Clutch, Transmission, Differential, Axle & Transfer Case 3 11-14-2015 09:12 AM
2004 F250 Grinding noise when hubs are engaged bublitz3 1999 to 2016 Super Duty 3 12-29-2014 06:42 PM
1999 F250 V10 No Start andy81563 Modular V10 (6.8l) 1 10-27-2014 11:41 PM
Transmission problem coloradotrk 1999 to 2016 Super Duty 5 10-24-2014 06:01 AM
Tags
05, 5r110w, body, common, diesek, duty, end, f250, ford, oil, problems, rear, solenoid, super, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
