Do my heater hoses look different? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-25-2012, 08:43 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
I don't recall seeing this configuration in any of the recent hose pics. Is the T in the hose running from the firewall to the passenger bloack normal? The T runs down to the radiator and clamps on near the drain valve.
Old 04-25-2012, 08:57 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Looks just like mine. I'm having a heck of time finding a 5/8" x 1/2" x 5/8" tee to replace the OEM one if need be. Could make up something if push comes to shove I guess. Not sure if anyone makes that hose anymore. Ford said no.
Old 04-25-2012, 09:04 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is gaining momentum as a positive member of FTE.
looks just like mine.
Old 04-25-2012, 09:07 PM
Ken_C's Avatar
except my coolant tank isnt all brownish what kind of coolant you runnin? well water?
Old 04-25-2012, 09:12 PM
redman84's Avatar
Cool. I don't know what I though was different. I guess I've just missed that T in all the other pics.
Quote:
Lol. Nah. It's all covered in dust but looks a little different too after I put that pinky purplish fleet charge in there the other day. I did oil, coolant, and oil cooler all at once a few days ago.
Old 04-25-2012, 09:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Wink
Quote:
X2 here
You can barely see the "T" behind the IC pipe in this pic
Old 04-25-2012, 09:15 PM
Ken_C's Avatar
fleetcharge isnt green? didnt know that. thats what I would use should the need arise.
Old 04-25-2012, 09:25 PM
redman84's Avatar
Nah. I'm not good with the whole color scheme so I call it pinky-purple. It was pretty nice to just pour in and go and it was cheaper than Prestone Heavy Duty. We'll see how long the SCA holds up.
Old 04-25-2012, 09:38 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Just before I took off my tank started leaking. I've used a few used ones but this time I ordered a new one from partsguyed. My My, its so pretty with the pink Fleet Charge in a new whitest clear tank.
Old 04-25-2012, 09:52 PM
nomad221's Avatar
nomad221 nomad221 is offline
nomad221 is starting off with a positive reputation.
C'mon Glenn, you have to post a pic now.
Old 04-25-2012, 09:56 PM
pjwoolw's Avatar
Quote:
Part number?
Old 04-25-2012, 10:00 PM
redman84's Avatar
So it's pink eh? Hey where did you get your coolant filter base? I want one with more than two ports to put a temp gauge in.
Old 04-26-2012, 01:40 AM
dieselsite.com. You probably just want to DIY so I'm not much help. Good Luck
Old 04-26-2012, 06:47 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
T is normal.
If I remember correctly I got a new lower hose to replace that one and although it had the proper bends to go under the radiator, it was just the lower hose from teh T down. I had to cut the T out of the old hoses and use it to make a new hose.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 04-26-2012, 08:08 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I am thinking that there was something different in those hoses between the '96 I drive and the '95 I parted out. Maybe it was just the location of the T? I can't remember now, but I know that there was something different about either the heater hoses or the radiator hoses and their routing. I would have to pull them out of the loft and look at them again to see what the difference was.
OBS supercab front bench redman84 Ford Truck Parts for Sale 1 08-15-2014 11:36 AM
Build Sheet: International Water Pump redman84 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-14-2014 01:26 AM
I need a driveshaft measurement redman84 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-08-2014 11:58 AM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Doing oil cooler. How does this go back in? redman84 1994.5 - 1997 7.3L Power Stroke Diesel 9 04-23-2012 09:52 PM
Tags
1979, 1980, 351m400, 73, 96, big, diy, exhaust, f250, f350, ford, heater, hose, intake, outtake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
