Do my heater hoses look different? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-26-2012, 11:08 AM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
Originally Posted by DIYMechanic View Post
I am thinking that there was something different in those hoses between the '96 I drive and the '95 I parted out. Maybe it was just the location of the T? I can't remember now, but I know that there was something different about either the heater hoses or the radiator hoses and their routing. I would have to pull them out of the loft and look at them again to see what the difference was.
If it was an early build with the early style radiator, they had different radiator hose routing IIRC. I know for a fact that the upper hose is different on the early models. Not sure about the heater hoses on the early model
Old 04-26-2012, 11:46 AM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Quote:
That may be it. I'm looking at Ford4Life7.3's coolant filter thread and the hoses on his 95 are opposite from mine. His passenger side hose appears to be going over the alternator down to the pump and driver's side hose going down by the bottle to the block and I don't see the factory T going down to the rad. Or does he need to swap the hoses and T as they run from the firewall to the other respective hoses from block and pump?
Old 04-26-2012, 12:01 PM
redman84's Avatar
Like this?
Old 04-26-2012, 12:36 PM
I just looked at my heater hoses. Mine does not have a Tee in it. It just runs straight down to the head. I guess the early models didn't have it.
Old 04-26-2012, 12:43 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I don't know if this matters or not but when I ordered a new coolant overflow bottle partsguyed asked me if mine had one or two hose connections?
Old 04-26-2012, 12:51 PM
Quote:
That's b/c the early build trucks. Mostly '94.5 and early '95 had an overflow bottle and had a cap on the radiator. Ours don't have a cap on the radiator and we fill through the bottle, so it has a hose that runs down to the lower radiator hose to fill the radiator. Early builds only had an overflow hose going to the bottle.
Old 04-26-2012, 01:33 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
The '95 I parted out had the same style radiator as in my truck (except it was a manual core and not the auto core) and had the degas bottle with the cap on it, instead of having the cap on the radiator like the early build (94.5) trucks did. I am almost sure that the heater hose had no tee in it and the hoses just went straight from the heater core to the water pump and head respectively. It seems to me like I thought about using one of the hoses out of the 95 on my truck then realized that I would have to change several hoses since there was nowhere to connect the hose from the tee in the heater hose. I believe both the heater hose and the lower radiator hose were different.
Again, I would have to look at them again to be sure what the difference was, but I know there was a difference. I will try to remember to take a look at them tonight and snap a couple pictures.
Old 04-26-2012, 03:23 PM
That's exactly how mine is. It's a '95 with the late model radiator and pressurized degas bottle, but the heater hose does not have a Tee in it like the others.
Old 06-11-2014, 10:47 PM
rusty1161 rusty1161 is offline
rusty1161 is starting off with a positive reputation.
Quote:
Originally Posted by pjwoolw View Post
Looks just like mine. I'm having a heck of time finding a 5/8" x 1/2" x 5/8" tee to replace the OEM one if need be. Could make up something if push comes to shove I guess. Not sure if anyone makes that hose anymore. Ford said no.
Google lead me to this thread, as I am searching for the same fitting. I did come up with this 5/8 x 5/8 x 1/2" Tee in case anyone else is searching for it.
Rusty
Old 06-12-2014, 09:31 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Arrow
Quote:
Rusty
Old thread, but good info. Thanks for share that. reps sent.
Old 06-13-2014, 04:52 PM
I just ordered one, and the company is pretty dang good. Refunded me on my shipping cost since they found a cheaper route, and didn't even have to ask.
Rusty
Old 06-13-2014, 06:03 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Thumbs up
Rusty
Good to know and for you
Build Sheet: International Water Pump redman84 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-14-2014 12:26 AM
I need a driveshaft measurement redman84 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-08-2014 10:58 AM
can this truck sell for 8k or possibly more? 1995 shortbed flareside 5.0 302 2wd about 180k miles bmad19 1987 - 1996 F150 & Larger F-Series Trucks 40 08-28-2013 07:00 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 12:38 PM
1989 F150 rear frame repair done. pics Bluethunder3320 1987 - 1996 F150 & Larger F-Series Trucks 0 07-13-2012 10:59 PM
Tags
1979, 1980, 351m400, 73, 96, big, diy, exhaust, f250, f350, ford, heater, hose, intake, outtake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
