09 f350 SD random pulls in steering - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-25-2012, 07:34 PM
09SDFordguy 09SDFordguy is offline
09SDFordguy is starting off with a positive reputation.
Hey, ive been reading through these forums since i bought this truck, this site is awesome. Anyways, i just bought a used 2009 F350 SD about 4 months ago. Came with new tires and was running fine until this week i noticed a pull in the steering wanted to wander left a bit. So, i would counter-steer to the right and it would feel tight for a second and then pull me right. This happened about 3-4 times now in the last week, i dont hear any noises that i know of. Jacked up the front end to see if there was any play in the hub or front end everything seems to be tight. It doesnt happen all the time but every now and then itll scare the **** out of me, anyone else had this problem or know what it might be ? ive only owned this truck in the winter months and now that its warming up ive noticed this problem, not sure if its the spring ruts or what. im running michelin at2's at stock size 275 70r18 i beleive. Im probably gonna throw it into the shop here soon just wanted to know if this was a common problem. sometimes ill turn left and it wont want to return to centre. anyways, ill keep on reading up on the forums here. Love the truck, want to do the DPF/EGR delete and maybe get a lift/mud tires soon but i got to get the truck running sound stock first appreciate any suggestions.
Cheers
Old 04-26-2012, 06:17 PM
cmalley12 cmalley12 is offline
cmalley12 is starting off with a positive reputation.
my truck does something similar.... it definitely needs an alignment... but the problem i have is when u start braking the truck will want to pull either left or right and it doesnt do it all the time...its wierd... checked the brakes everything is ok....gonna endup bringing it in to the shop eventually as well.... keep us posted on what u find... good luck!!
Old 04-26-2012, 06:27 PM
R-T0r21on R-T0r21on is offline
R-T0r21on is starting off with a positive reputation.
My guess would be the steering gear.
Old 04-26-2012, 07:28 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Steering gear seems right to me. You could try to rotate tires first, flush the power steering system as well.
Old 04-27-2012, 05:28 PM
BASSHUNTER's Avatar
BASSHUNTER BASSHUNTER is offline
BASSHUNTER is starting off with a positive reputation.
My 2008 61000 miles was doing that similiar steering issue,Replaced the lower r/s tie rod assy and the tie rod assy off the steering gear and it tightened up the steering and got rid of my Death Wobble that i have been fighting and threw alot of $ at! Wished i hadn't spent the 800.00 on adjustable track bar and replaced ball joint on my stock one.Would have saved 650.00 and lot's of bump steer!
Old 05-01-2012, 11:54 PM
Update, ok so its been a week or so since i posted last, same thing still happening, but, ive narrowed it down to, sometimes after i start my truck it does it, and then ill pull over to the side of the road, put it in park and start driving it, and its fine !?!?!?! wtf, does that mean its not mechanical ?? could it be something in my computer trying to compensate steering ??? this cant be, anyone got any ideas ? am i the only one who has had this problem ?
Old 05-02-2012, 05:26 AM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
check your front axle u-joints could be stiff.
Old 05-02-2012, 07:01 AM
The computer has nothing to do with the steering. Did you ever get the steering gear checked? Cuz that's still my bet.
Old 05-14-2012, 06:59 PM
Hey! finally got my truck into shop, front axle u-joint is seized aparently u need to do some vacuum gasket when u pull it apart, hopefully this fixes the problem, thanks for all the help hit the nail on the head my auto 4x4 never worked anyways, maybe this will fix that too with the new vacuum gasket. i get my truck back tomorow, ill post updates !!!
Steering issue JRS2 1987 - 1996 F150 & Larger F-Series Trucks 3 08-29-2016 06:19 AM
1973 F250 Long Bed Single Cab "Build" misscali91 1973 - 1979 F-100 & Larger F-Series Trucks 38 03-01-2016 05:44 AM
random death wobble Edkajo 1999 to 2016 Super Duty 0 06-14-2011 09:39 PM
couple issues, help please? powerstoked! 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-27-2010 04:05 PM
Truck Still Drifts Like It Did 2 Months Ago Also WIth Vibe xjcamaro89 2004 - 2008 F150 20 07-12-2009 07:20 PM
Tags
2004, 2006, 2008, 350, 64, f250, f350, ford, power, problems, pulling, pulls, random, side, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
