What I do know is each FICM is programmed to the specific vehicle. You would have to take it somewhere to get it programmed for your vehicle, assuming there wasn't a change in the FICM between the model years.
4 screw and 7 screw FICM's will interchange. There can be a software issue between FICM and PCM depending on the version. If so it will run but set a code for software compatibility. Most of the time they work with no issues.
i changed the ficm and the truck is runing fine so far. but i am getting that code u0306 software incompatibility with ficm. will that cause any problems to run it as it is or what should i do?
Drats! You're gonna need a flash from the dealer to fix it (they will flash all three modules). Power Hungry Performance or Ed@FICM repair.com can flash just the FICM but you have to send it to them. they also offer performance flashes the dealer doesn't have which is a plus. If you still have your old FICM maybe you could send it in for repair and possibly upgrade. I don't know what issues driving long term with the software incompatibility may cause but obviously you want that light out.
