1986 FORD f250 460 BB WANNA PUT c6 in
just as the title says i got a 86 f250 i put dana 60 in front its got the automatic 3 speed im not sure what trans and i think a 208 transfer case, well i burnt that trans out with the 44 inch tires now i can get a c6 and i hear there stronger but will my transfer case work? or do i need a 205?
They usually had the E4OD (4 speed auto) behind big blocks in the 90's for an automatic... but I believe up until around '96 you could still get a C6 behind a big block on the heavier trucks (F350s).
The only problem you might run into is the output shaft, 2WD is different from a 4WD. As for the E4OD, it's only 3" longer overall than a C6, but the mount pad is 7" further back. It also is computer controlled and won't work on an 86 460 unless you buy a standalone transmission controller.
danev2
05-09-2006 10:19 PM
