Truck runs good but problems
Old 04-25-2012, 12:17 PM
Regulator1988's Avatar
Regulator1988
Regulator1988 is offline
I have no check engine light but I read 3 codes
P603
P1000
P2285
Help help!!
Old 04-25-2012, 02:04 PM
bpounds's Avatar
bpounds
bpounds is online now
P603
P1000
P2285
Help help!!
P0603 and P1000 happen when batteries are removed, or maybe when they are failing and the voltage goes too low during cranking. By themselves those codes are not a concern.
The P2285 means your injection control pressure was low at some time. I wouldn't jump to any conclusion on that unless it becomes persistent. Reset it and see if it returns.
Old 04-25-2012, 02:22 PM
69cj's Avatar
69cj
69cj is offline
I would also get the batteries load tested. If one or both are weak they can cost you an ficm. Always replace them in pairs if you do have a weak one.
Old 04-25-2012, 02:25 PM
Regulator1988
I replaced one with a platinum diehard but I guess I need to do the other also?
And I have reset it a few times and it comes back
Old 04-25-2012, 02:27 PM
69cj's Avatar
69cj
69cj is offline
If the other one is weak it will kill your new battery in short order not to mention the ficm.
Old 04-25-2012, 02:28 PM
Regulator1988
The voltage for that is 48v
Old 04-25-2012, 02:31 PM
bpounds's Avatar
bpounds
Should always replace these batteries in pairs.
Now on the ICP, if it is coming back, your next step should be to find your ICP. On an '03 it is probably under the turbo at the back of the engine. A bitch to get to, and also prone to failure back there. Find it and check for traces of oil on the sensor and wires. Bad wiring there could be the source of all 3 of those codes.
Later engines have the ICP in the passenger side valve cover.
69cj's Avatar
69cj
69cj is offline
It's a 12 volt battery, not 48 and a voltage reading does not constitute a load test or are you referring to ficm voltage. You need that while cranking and running.
Old 04-25-2012, 02:33 PM
Regulator1988
For the ficm
Old 04-25-2012, 03:46 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
When you replace spark plugs, do you do one bank? Or all of them.
Replace both batteries not just one!
If you keep getting the 2285 code, replace icp and pigtail
Old 04-25-2012, 03:55 PM
Regulator1988
They were out of stock on the other
Old 04-25-2012, 04:12 PM
raptor131's Avatar
raptor131
raptor131 is offline
These trucks have spark plugs?
Old 04-25-2012, 05:15 PM
2006powerstroke90
Just an analogy
Old 04-25-2012, 05:26 PM
69cj's Avatar
69cj
69cj is offline
Raptor doesn't miss a thing.
Old 04-25-2012, 07:19 PM
cheezit's Avatar
cheezit
cheezit is offline
Ok so I told you what you needed to do about the p2285 on the phone sorry if my awnswer was not good enugh, however as you see the same has been said.
next the p0603 is pcm reset. either the ther batter is junk as well or its a result of disconnecting the batteries or the cts itself pulling false dtc's
p1000 is simply a code that means all moniters not run yet.
so in short icp, icp pig tail, and ignor the other to dtc's at this time.
Quick Reply: Truck runs good but problems
