Lift gate won't open 2002 Escape - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 04-25-2012, 12:49 PM
Ervin2002 Ervin2002 is offline
Ervin2002 is starting off with a positive reputation.
Is there a manual way to open the lift gate from inside? There's a small access opening at the bottom where I can see the stuck latch, but poking around in there doesn't seem to do anything.
Thanks Erv
Old 04-26-2012, 08:21 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
You will have to remove the 4 screws at the bottom, and then pull the inside panel free for access to the mechanism. If the door is stuck closed, you can manipulate the inside panel loose from the door at the top enough to gain access to work the linkage by hand. It is not fun, but can be done without ruining anything. You may have to get some new 'christmas tree' plastic fasteners if the old ones are too distorted to work.
tom
Old 04-26-2012, 11:20 AM
Thanks for the response, tomw...but my problem is that the lift gate is locked/stuck in the closed position; I can't get it open. Hopefully, someone has an answer to releasing the latch from the inside of car through that access hole at the bottom. It'd save me a hundred bucks just to have the dealer "look" at it.
Old 04-26-2012, 11:27 AM
martin_csr martin_csr is offline
martin_csr is starting off with a positive reputation.
Yours has an access hole? On the inside? Can you post a pic. Mine doesn't.
From reading other topics, you may have to peel away the plastic from the inside. It's held in place by spring clips... just pull the plastic off at the top so that you can reach in to get at the rod. When I removed the plastic, the hatch glass seemed to be in the way, so I don't know how problematic that might be. I was able to open the glass, before removing the plastic... nothing was broken or anything.
This is a known problem w the Escape, so I removed the plastic interior shroud & drilled a hole in the plastic at the actuator/rod linkage for future access for if ever mine breaks. I plugged the hole w a black plastic plug from Lowes.
2002 XLS. 1st pic: I think the actuator is in the locked position.
Old 04-28-2012, 10:47 PM
Access Hole...
Sorry, couldn't get a picture, but the access hole is of no use...all that is available thru the hole is the boss that the latch hooks onto. The locked latch finally responded to the key fob and opened, I immediately installed the replacement actuator, which cost me $10; Ford wanted almost $400. They only sell the whole assembly.
Old 06-20-2012, 01:53 PM
nuclearwhiskey nuclearwhiskey is offline
nuclearwhiskey is starting off with a positive reputation.
I had to do this to my escape, I bought the generic and it has worked great ever since.
Old 10-28-2012, 05:55 PM
chap442 chap442 is offline
chap442 is starting off with a positive reputation.
where did you purchase a generic actuator? I need one
Old 10-28-2012, 08:39 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
Stereo shops generally carry them - $10ish in my area.
Check this out:
Universal Power Door Lock Actuator Car Auto Best Deal | eBay
97 expedition interior lights Tom Compton 1997-2006 Expedition & Navigator 16 10-24-2016 03:11 PM
Tailgate cap superrangerman2002 1999 to 2016 Super Duty 4 07-07-2016 02:24 AM
Back hatch issues RDockery 1997-2006 Expedition & Navigator 8 12-21-2015 10:22 PM
Inside lift gate release pkthomas Excursion - King of SUVs 0 05-13-2014 02:38 PM
Lift gate problem on 1998 Mercury Mountaineer Josh2021 Explorer, Sport Trac, Mountaineer & Aviator 1 07-21-2010 05:43 PM
Tags
2002, 2010, actuator, cylinder, esape, escape, ford, hatch, liftgate, lock, open, picture, plastic, rear, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
