Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Oil light flickering
Old 10-26-2012, 10:28 AM
tacdrivrnc's Avatar
tacdrivrnc
tacdrivrnc is offline
I have an 04 Escape with 125,000 miles, keep the oil changed regularly with 5w20 full synthetic, and what ever decent oil filter is on sale at advance auto (yeah, it could have a fram on it righ now, but I think it's either a K&N or a Bosch). Recently changed the plugs, coils, and all top end gaskets just to avoid problems. The other day the oil light flickered under moderate acceleration on the highway. I checked the oil and added a quart since it seemed low. Oil light flickered one more time a week later and has been fine for a few days now. What causes this?
I haven't had a chance to check for smoke behind the car but will find a volunteer to drive it while I ride behind it. The tail pipe has some blackening at the edge, but that has been there for a while. The engine runs strong and starts right away, and idles smoothly.
Ideas?
How can I install a oil pressure gauge and mount in the cab?
Old 10-26-2012, 02:08 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Ideas?
Could be the OP sending unit is going bad, if you can, check for actual oil
Pressure.
I install Autometer electric, not mechanical, gauges in my trucks.
These require using a T at the OP sending unit location on the engine block.
An oil line runs to the Autometer OP sending unit(which must be grounded to
The truck-body-)
Then a wire is run into the cab, to the gauge.
Mount gauge in a pod or in the dash.
Old 10-27-2012, 11:53 AM
scott91370's Avatar
scott91370
scott91370 is offline
I have had at least 2 fords that had this happen and was lucky it wasn't the actual sending unit but the plug that hooks to it getting worn and not sending a good signal. Installed a new end and one was good, the second - still flickers - I'm not going to worry about it.
Old 10-29-2012, 06:02 AM
tomw's Avatar
tomw
tomw is offline
The sending units will 'close' when the pressure falls below ~5 psi. They can also fail mechanically, causing hemorrhage of the oil if the bakelite-metal joint becomes loose.
If the light is flickering, either the switch is grounding or the wire between the light and the sender is getting grounded by damaged insulation from age or chafing. A loose connector would not make the light turn on unless it provided a ground.
tom
Nally427
20
04-22-2019 07:17 AM
Chiefdan
05-27-2018 07:50 PM
1966f100ranger
09-11-2017 10:37 AM
virginiacreeper
02-06-2012 08:31 AM
slouis1948
04-13-2005 07:07 PM
Quick Reply: Oil light flickering
