what did this dana 60 come out of?!
Old 04-25-2012, 11:35 AM
winklershop's Avatar
winklershop
winklershop is offline
I have a Dana 60 rear axle and i cant find out what it came out of. Usually there is a BOM number on the ratio tag that is bolted on the differential cover. There is a tag but it only has these numbers:
C5TA RD 2679-1 410
decoded says 1965 ford truck chassis....4:10 ratio
i think the 2679-1 is a part number?
usually there is BOM number on these aluminum tags, but this one just does not have one. I know to look on the axle tube also for the BOM number but this is all there is on the right tube if you looking at the diff cover:
77 5C1 2679 1
there is also a casting # C30255
and
patten numbers
US PAT 2018188
US PAT 1988618
Let me know what you guys think!!! Thanks!!! I need to know what truck this came out of so i can order parts that go on it, brakes, drums, bearings ect...
Steve
Old 04-25-2012, 11:52 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
Ford ID tag: C5TA-RD = Spicer/Dana 60 / 4.10-1 / non Limited Slip / 5,200 lb. Rear Axle Capacity
Axle housing ID tag number: C5TA-RD = Ford part number: C5TZ-4010-G / 1965/66 F250 2WD / 11 degree spring pad angle.
2679-1 = Spicer/Dana part number / No BOM on ID tags of trucks of this vintage.
Originally Posted by winklershop
I need to know what truck this came out of, so I can order parts that go on it, brakes, drums bearings etc.
Now you know what trucks it was used in, but you're gonna need more info than that to ID the brakes/drums and etc.
What size are the rear brakes shoes, 12 1/8" x 2" or 12" x 2 1/2" ?
1966 was the first year Ford offered 12" x 2 1/2" brakes, standard equipment on 1966/72: F250 Camper Specials, and with GVW's of 7500 & 8100 lbs.
1966/72 F250's with the 6100 GVW have 12 1/8" x 2" brakes as do...all 1953/65 F250's.
Old 04-25-2012, 12:24 PM
winklershop
Thanks for writting back, i need to get the rest of the parts here that came off that axle to find out what size brake pads...ill post what size brake shoes came off that axle.
Old 11-04-2012, 03:34 AM
Monster Van Mike's Avatar
Monster Van Mike
Monster Van Mike is offline
Welcome to FTE
Hello I saw your above post and thought maybe you could help me with the following question. I am trying to ID the rear axle in my '97 E350. I couldn't find a BOM but in the web around the cover I found the following casting numbers....Rear said AC on both sides at the top and 47510 in the lower left. Front showed 248-011 on both sides at the top and 7114 in the lower right. I think its a Dana 60 but want to learn more about it from the numbers.
Thank you for your help!
Old 11-04-2012, 04:49 AM
NumberDummy
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
1997 E350 with SRW (Single Rear Wheels) could have either a Dana 60 or a Dana 70, both look pretty much the same. There are different sized ring gears associated with each type.
I need the AXLE code to determine which axle it has.
The AXLE code is printed on the Certification Label that is glued on. Also has the VIN and many other codes printed on it. Could be on the B pillar below the striker plate, or on the face of the left door.
Dana rear axle ID tag located under one of the bolts that retains the inspection cover to the housing.
There may be an additional Dana axle ID tag: 2" x 1/2" metal tag bolted to the housing adjacent to the inspection cover. Will have a 7 or 8 digit Dana ID number stamped on it, like 603010-1 or 603010-11.
Post the codes.
Old 11-04-2012, 05:53 AM
Monster Van Mike
Thanks for the reply! That was fast . I haven't found any tags on cover bolts or anywhere else but I have looked for the BOM code on the right axle tube and can't see one but I will try to clean it and power wash it to see if that helps. The axle code on the sticker inside the driver's door is 34. Here are other numbers from the bottom of that sticker:
WB = 138
BRK = C
INT = D2
R = 9
AXLE = 34
TR = E
SPR = LS
One more thing the rear GAWR on that same sticker is 6084 lbs if that helps.
Thanks again.
Old 11-04-2012, 06:25 AM
NumberDummy
1990 and later: All the AXLE code lists is:
34 = Dana Rear Axle (E250/350) / 3.73-1 / no Limited Slip / 6,340 lbs. Rear Axle Capacity.
But which Dana? With the 6,340 lb. capacity, I doubt it's a Dana 70.
Contact local dealer, pass along your VIN. When it's typed into FoMoCo's computer system, the rear axle type will be known.
FTE has an Econoline forum "1968 - Present Full Sized Vans" / You might ask this question there.
FTE has a Ford Dealer Parts Dept sponsor: tousleyfordparts.com / Tousley Ford ~ White Bear Lake MN
You could contact them for assistance.
Old 11-04-2012, 07:21 AM
Monster Van Mike
Thank you, Bill. I will do as you suggest.
Have a good rest of the weekend.
Mike
Gigemags05
1947 and Older Ford Trucks
11-22-2014 07:41 AM
55F250
08-12-2009 03:55 AM
Green_Monster
05-23-2004 05:48 PM
rmagoo
09-23-2003 10:09 PM
78 Swamp Donkey
03-03-2003 09:27 PM
Quick Reply: what did this dana 60 come out of?!
