Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-25-2012, 11:03 AM
77f-250 77f-250 is offline
Garage is empty, add now
77f-250 is starting off with a positive reputation.
wiring problems ??
I've got a 1979 ford f-250 4x4 with a 360 and c6 tranny (76 running gear) im trying to figure out the brake lights. I checked the brake switch on the pedal and no power there two wires simple enough, one lead me to the turn signal fuse, so i wanted to trace the other one but the wires been spliced into several different colors and i cant chase it through the firewall and was wondering if someone knows where the other wire ends up at.Then i have no dash lights checked the bulbs are blown so need new ones of those so i swapped a few used ones in that still work. Played with the dimmer switch followed some wires and am kind of lost at what it could be. and last does anybody have a wiring diagram from the cab back that i dont have to squint and hunt for the plugs?? Thanks for all the help.
  #2 (permalink)
Old 04-25-2012, 11:09 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
Here you go, factory wiring diagram 1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
