Got an oil change coupon - Ford Truck Enthusiasts Forums
Old 04-25-2012, 10:57 AM
2horses's Avatar
2horses 2horses is offline
2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.
From my dealership today - Oil and filter change special plus tire rotation for $89.95. Regularly $129.95. The first two (and only, so far) oil changes were free, so do these numbers seem right? It's not even synthetic oil, from what I can tell.
With my '06 (may she RIP), I would buy the synthetic I wanted and then take it to a different dealership for the change and to get it checked out, that was only about $30.
So it would seem that the non-synthetic oil change would be cheaper. Maybe it's the filter, too.
What do y'all think? Deal or no deal?
Old 04-25-2012, 11:09 AM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
That seems to be the going rate around here at our local Ford garage.
Old 04-25-2012, 12:30 PM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
2horses,
I am not sure if it the same deal - but when I got my 2011 - Ford sent me that Fordowner.com card - I did register & they have those kind of deals at the dealer... Mine being the 6.2 it is "the Works" rotate & oil change, check brakes, battery, etc.
I am not sure if this is what you are looking at - although for the diesel. I did see one for diesel and that price sounds like the same..
If it is the same - mine says (in small print) up to 5 qts. If that is the case - they will charge you more than it says. Also, Be aware - my dealership doesn't have a code for this - so they punch it in & it always comes out a good bit more. And to top that, one day a service writer called & told me that my truck was 8 lugs not 5 and that would be $5/wheel extra..
But the service/part manager is almost a neighbor up at the ranch so I have no problem getting him to fix the bill...
Just be aware of the pitfalls - good luck...
Byram
Old 04-25-2012, 01:39 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
My dealer charges $79 for a regular oil change. Tire rotation is extra. So $89 for both is OK deal.
Make sure you sign up for the Ford Owner advantage. Every 5th Oil change is FREE. So four oil changes at the $79 ( or in your case $89) and the 5th oil change is free. Ford tacks it in their computer that the dealer sees.
Old 04-25-2012, 01:56 PM
Byram's Avatar
Yea, Forgot to mention that.......
Old 04-25-2012, 02:06 PM
2horses's Avatar
I've got the owner advantage stuff going on and have credit for the two oil changes I've received so far. I also checked the coupon and no fine print about limiting quarts, it is specifically for diesels so one has to assume it's for at least the thirteen we need - although the fine print does say, "Some models may be slightly higher." WTH?
Old 04-25-2012, 02:18 PM
CornTruckDriver's Avatar
CornTruckDriver CornTruckDriver is offline
CornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud of
Quote:
Originally Posted by Byram View Post
2horses,
Byram
Wow !!!!!!!!!!!!!!!!!!!!
I wonder if they counted the number of turns it takes to remove the oil filter!
Old 04-25-2012, 02:26 PM
buckmasters's Avatar
buckmasters buckmasters is offline
buckmasters is starting off with a positive reputation.
When I got my truck, I got coupons in the mail for 1 or 2 free oil changes. So I drive all the way back to the dealership for my first oil change without reading the fine print - it was only good up to 5 qts. or something along those lines. They wanted another $30-40 extra for the 6.7L. I told them no thanks and started changing it myself - costs me about $50, I don't have to wait around at the dealership, and I know it's done right.
Old 04-25-2012, 03:37 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
I got 6 free oil changes from my dealer. Guess I got a pretty good deal...
Old 04-25-2012, 05:45 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I'd say that's a good deal. My first oil change was $107.
Old 04-25-2012, 05:53 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
you can do your own oil change for that price with Mobil1 5w40 full syn. and be the baddest chick in texas at the same time.
Old 04-26-2012, 07:00 AM
mrjc's Avatar
mrjc mrjc is offline
mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.
I get the coupons from our Ford Dealer here and use them. $59.95 and a penny tire rotation. After tax and "shop fee" it is 70 bucks. We have a quick lane for oil changes (2 hours) Ask your dealer if they add a shop fee (to dispose of the oil and rags). That might put your 80 dollar oil change at 100. 13 qts @ $4.50 a qt and filter for 15 bucks would be worth it to have the dealer do it. For my old 6.0L the coupon was worth it! Still have not gotten to 2K miles yet, but was thinking of buying a maint coupon book they sell here with oil changes and other maint stuff in it. The diesel oil changes average out to 40 bucks. Just suspicious. I take it since you have not heard "clicking noises" after your oil change your dealer put the correct amount of oil in? They make them smarter in Texas. Mike
Old 04-26-2012, 07:08 AM
Byram's Avatar
Quote:
Doing her own oil change or not - 2horses has already proved to be pretty tough - read her posts - awards for breaking colts - I broke colts & lots of them years ago & to doing it right is a lot of work and sometimes just a little pain
Old 04-26-2012, 07:19 AM
Then doin an oil change should be a piece of cake.
Last dealer oil change i had was on my 6.4...took it in for rear diff fluid and trans fluid and told em i didnt need oil change as it was just done less than 1k miles prior(Mobil1 full syn of course). Well they mistakenly changed my oil (didnt charge for the mistake), didnt use a new crush gasket (flipped it) and didnt properly torque the drain plug (which i noticed when i saw oil on my driveway during my daily walk around inspection-grrr).
Shops (dealer or not) get paid by jobs, not attention to detail. Sure, sometimes you get lucky and find both. But most often, the work is done as quick as possible to get you out and the next guy in. Its a vicious cycle. The worst is a friday afternoon with a worker that hates his job and wants to go home.
I do as much as i can myself and take my time and am as meticulous as possible. And if i screw the pooch, i take full responsibility and learn from it.
Plus these trucks are super easy to do basic preventative maintenance like oil, filters, etc..
Old 04-26-2012, 07:41 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Two years ago the local dealer up here charged me $69.99 to do an oil change on my 6.4L truck. This truck took two more quarts of oil and used a more expensive oil filter than the 6.7L engine does. I guess it depends on the area you live at though. My first oil change on my 6.7L truck was free courtesy of a warranty turbo replacement!
And I also advocate changing your own if it makes financial sense to. Not always the case I guess...my wife's Toyota requires full synthetic oil and with the oil and filters from Wal-Mart it would cost me $46 to change. The Toyota dealer charges $49.99 and includes a car wash with the service, so it makes no sense for me to do it myself.
Synthetic oil popatop500 Modular V10 (6.8l) 109 12-27-2016 08:28 PM
Questions for oil change Bohen 6.7L Power Stroke Diesel 4 10-03-2016 06:01 PM
Motorcraft oil Smokey01 2004 - 2008 F150 15 04-06-2010 07:18 AM
Synthetic Oil for a 2005 Expedition froger25 1997-2006 Expedition & Navigator 5 06-02-2006 07:19 AM
Synthetic oil gembeau Oil & Lubrication 4 08-14-2001 02:36 AM
Tags
2012, 60, change, coupon, coupons, deisel, diesel, discount, f250, ford, maint, oil, pa, package, special
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
