Carrier Bearing Shim With Pics
I thought I would share some pics, when I looked around to build my own I could not find any using the search button. These are from a procomp shim kit from Summit Racing. Part# EXP-52480.
They use a 7/16 bolt that is 2 1/4 inch long.
With this kit you get 6 spacers that add up to a total of 1.5 inch of carrier shims.
Idk why but I can't get the 1st picture to save the right way so you will have to turn your head to read it.
Part is 8 inches in length though.
Could you expand on this? I am getting a vibration around 70-75 mph. I did replace my driveshaft carrier bearing as the rubber was getting shot but it didn't help. Figured I would try this before paying to have driveshafts balanced.
2005 Ford F20 Crew Cab 5.4l 3 valve
Countrywfo
08-06-2014 08:01 PM
