Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 04-25-2012, 02:35 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
P0478 code
I had a bit of creeper time today and so did some PM (preventative maintenance).
First read the codes with my Superchips code reader. I had the usual AIH code (cause I've deleted the AIH), and a couple of others that I'd seen before. However I got a P0478 for the first time - it's an exhaust back pressure fault code.
This could be because I've removed the EBPV and put on the delete pedestal.
I followed Guzzles post for cleaning of the sensor and line. We've been snookered cause the RHD steering box limits access to the manifold end of the line. And I don't have a deep 1" socket. So that job is going to have to wait for another day.
In honour of Bryan's GTG smoke puff run I changed the Superchips tune on my truck to Hi Perf - No Tow and went and blew a few puffs of my own !
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
Tags
2002, code, error, excursion, ford, p0478
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
