My Coolant Filter Install/Write up
No, if you see both pics, the "T" in the Talyn´s pic (the only one you can see and goes to the water pump to the heather) goes at the top of the base filter and your goes to the side, as I can see.
#28
Rob
I wouldn't fix it yet unless you have a new filter to put on. Because it has been flowing backwards for the past several months any sediment that has been collected will be in the center tube of the filter instead of trapped in the pleats. Once you hook it up the right way all that junk will be washed out of the filter and back into the water jacket.
#29
Rob
